TYE flexible unit planter
/ TYE flexible unit planter #1
harrisonkats
sherman,tx
1972 ford 3500/1951 ferguson
dose any one own or have used a TYE flexible unit planter it is a plate less planter
how would you rate it 1-10
it was bought out by ACGO in 1999 and shut down later
/ TYE flexible unit planter #3
I've seen Tye drills, but not a unit planter. I can't quite make out if that thing is a 3 point or not. The tires, with the shovels right behind it, is pretty unique. I haven't seen anything quite like it. In 1980, most planters were still plate planters. How does it singlelate seed?
3 point the wheels are at the front behind the tractor. ive never planted any thing yet. going to plant a garden maybe 5ac. found this planter for 285 but no one has heard of it or used one like the planter be for.( that could be a bad sign)
im a little late on the plowing just learning to set the plow up taking it one step at a time
How does it singlelate seed? split disk I believe. the rate is adjustable and the depth is adjustable.IMG_20150106_124208_885.jpg
40' High Cube Multi-Door Container (A62183)
40' High Cube...
2012 Dodge Challenger R/T (A62180)
2012 Dodge...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
John Deere 385 Baler (A64047)
John Deere 385...
SINGLE STAINLESS STEEL SINK (A63745)
SINGLE STAINLESS...
iDrive TDS-2010H...
