Tym 474 engine regen
/ Tym 474 engine regen #1
Bt298
Tym 474HST
At 107 hrs got the regen warning with the 3 beeps etc. Have a kukje engine, followed the instructions 2700 rpms, 76 degree coolant temp. Everything in neutral. Press and hold the regen button, but it will not regen, am i doing something wrong. I reset the light Can I do a forced regen. Any help would be great. Thanks
/ Tym 474 engine regen #2
I had trouble with mine and the tech put it into regen. If I remember correctly, he turned the machine off. Turned it back on, made sure the brake was on, throttled it all the way up and held the regen button in for a long time - 45 seconds or something. Make sure everything is off (PTO...) and the E-Brake is on.
/ Tym 474 engine regen #3
If you posted the same question in the FB TYM group, I will answer the same? Did you try to reinitialize the DPF controller?
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
Swict 72in Bucket Skid Steer Attachment (A64553)
Swict 72in Bucket...
2014 Kenworth T370 S/A 14ft. Cab and Chassis Truck (A64194)
2014 Kenworth T370...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
2009 Infiniti FX35 AWD SUV (A64557)
2009 Infiniti FX35...
