Ubifi Rural Internet
   / Ubifi Rural Internet #151
I have a few problem areas that I make my best effort at keeping going. Sometimes when the copper cables are severely deteriorated with multiple bad spots in between peds it can be difficult to isolate, dig up, and replace/repair the bad spot. Worse, is that we are not putting much money into refurbishment of bad areas of copper as it is all slated to be replaced by fiber in the not too distant future. In these areas that need long sections of cables replaced, but won't happen, we just try to find the best pair we can and hope it is a little better than it was before.
Another thing that is often overlooked with DSL is bonding and grounding. While it has always been important for voice quality, it is extremely important for DSL quality. The shielding on phone cables need to be bonded to power company grounds so that the shield and power ground is at the same ground potential. If, say, the phone ground is better power can induce onto the phone cable and use it as a path back to ground. I have fixed many DSL issues over the years by simply digging a trench 40' from my ped to a power pole and connecting a ground wire from my shield to the power ground.
Another problem is that it has become common practice in many areas for Telcos to contract out cable locates. Thes locators come out, disconnect the grounds from the cable to locate it, and then either entirely neglect to replace them or do not tighten them sufficiently causing issues for anyone feeding down that leg of cable.
Something else I have seen many times is the lightening arrestor (protector) inside the NID causing problems. I can test the protector and it will test out fine, it passes dial tone no problem, but will cause packet loss, CRC errors, HEC errors, and a host of other problems on the DSL connection. Remove the protector that tested perfectly good from the loop and voila! The DSL runs clean as a whistle! I don't know why either...
Anywho, I digress. If the problem is in the outside cable plant it would be nearly impossible to help you without seeing test results from the techs meter. I guess the only other easy thing you could do on your own is bypass your protector and connect your modem directly to the cable pair coming in. If that makes a difference, and it always surprises me how often it does, it would be something that could be mentioned to the tech when he comes out.
   / Ubifi Rural Internet #152
At the moment I’m not having a problem. My problem is speed. I’m looking for options to the DSL I get now. I’m wondering if Ubifi is right for me, and whether it will work when the line of sight to the tower is impeded when the heavy oak tree leaves come back in Spring.
   / Ubifi Rural Internet #153
All of our test results are logged and uploaded with the ticket for any employee to see. If you are trying to run DSL on 40 year old inside wire in the home the results will be bad. But if it is a self install meaning you, the customer, decided to wave the install fee's and do it yourself. Then we only test to the outside of the home. If we come inside you pay, simple as that. I would never suggest anyone do a self install. As far as fiber installs, there is never a self install option because the Cat 5 has to be run directly from the ONT to the Router and we test wired speeds at the router. There are no guarantees with wireless, simple as that. And there you have it.
   / Ubifi Rural Internet #154
He already mentioned that he ran a new Cat 5 from his NID, so that pretty much rules out IW as the issue. From everything Ive read, my guess is that the reason he can only get 3x1 service is a culmination of old copper in the ground and old DSLAM equipment incapable of vectoring.
How do you guys have your fiber plant set up? PON, possibly GPON? Who makes your ONTs?
   / Ubifi Rural Internet #155
GPON Calix
   / Ubifi Rural Internet #156
Are you guys using the 716GE ONTs? Have ya used any of the 844GEs Gigacenters yet?
   / Ubifi Rural Internet #157
All single family homes get the 721 GE and I only have 1 MDU site using the 717GE . All of our ONT's are outdoor type, we don't install any indoor in this market. Other areas do.
   / Ubifi Rural Internet #158
To give an update on the performance of our new Ubifi internet - :) - we have been using Ubifi at our new house for about 2 weeks. It works great. In fact, we purchased a Wi-Fi extender, set up the security, and our in-laws who live on the other side of the property (350-400 ft away) are using our signal for their Wifi. All are working great. This is with multiple devices. I found the best signal in our house based on signal strength in the direction of the closest tower. Once or twice it has buffered, but for maybe a few seconds.
   / Ubifi Rural Internet #159
What Wi-Fi extender and is there any vegetation in the line of site between you and your in-laws?
   / Ubifi Rural Internet #160
Just keep in mine those extenders suck wireless bandwidth to talk to each other, unless you get a Mesh System. Then those talk to each other over their own wireless band.
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
FAKE (A52472)
FAKE (A52472)
2015 Ford Focus Hatchback (A51694)
2015 Ford Focus...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
