I get it if I look at it. /forums/images/graemlins/mad.gif  Get it every year.  For anti-itch relief I always use that calamine spray and something I tried new this year that’s not as messy, the gel.  But the one home remedy that I highly believe in is bleach.  50/50 mixture of bleach and water.  Straight bleach irritates my skin too much so I dilute it a bit and within three days it starts drying up for me.
I did a little test about 3 months ago.  I got it on my belly and my arms.  Decided to hold off on the bleach this time and just try the anti itch sprays and creams.  Well it lasted for an aggravating two weeks as it normal does with little treatment.  I just got it again 5 days ago in the same areas.  Wiped the areas in 50/50 bleach and water and for the last two days it hasn't bothered me.  Dried up and barely noticeable now.  The bleach doesn't stop the itch right away but it does kill her and dries it out in a few days, I think. /forums/images/graemlins/smile.gif
A lot of what I've learned and researched about Poison Ivy is this:
--You cannot spread it by itching it. (It only flares when you scratch it making it look like it's spreading)
-- Only the parts of your body that the oily resin has come in contact with will be infected.  The resin penetrates your skin quickly and if you can wipe yourself off with alcohol in the areas infected shortly after contact you can prevent much of the rash from occurring.  Alcohol is said to absorb the oily resin.
--You cannot pass it onto others after you have disinfected and washed the resin from your skin and clothes.  The busting blisters are not what causes the rash it's the resin from the plant and your blisters do not contain this resin.
--If you have clothes, gloves, or equipment that has came in contact with the resin you can possibly get it again from coming in contact with these items.  Wash your clothes thoroughly.  Cleaning your equipment is a push over in my opinion but go for it if the stuff aggravates you that bad. /forums/images/graemlins/smile.gif
--Burning the plant, as other have mentioned it's a no, no. (Lungs, and other internal body parts will suffer harm.)
Speaking of burning Ivy, dummy me started a burn pile with a whole mature vine about 3.5 inches in diameter, piled a bunch of other brush on it and more poison. /forums/images/graemlins/crazy.gif  I've burnt about 5 burn piles this year already and that one is still setting there. /forums/images/graemlins/confused.gif  If I do get brave enough to burn it I'll be lighting it and running to the truck about 1/4 mile away.  But will see what I decide to do.  This one just might send me to the hospital for some steroid shots and I don't want that. /forums/images/graemlins/mad.gif But work has to be done and I don't see no way around it. /forums/images/graemlins/smirk.gif
I've been told Jule Weed is a great anti-itch plant.  If you can find it and distinguish what it looks like it works.  I found a patch of it on my land a few weeks back and it's pretty neat.  You break the stem off and rub the sap on the itchy spots.  I read somewhere that they're making it into a cream.  I wish I could find it in the stores somewhere.
There are all kinds of other stuff about the Poisonous plants you can research on the net.  I'm going way overboard here so I'm going to stop but it does help to understand the plant if you're severely allergic to it as I am.  And for those who don't get it, that is said not to be always true.  It's said that after contacting the plant several times one may eventually get it as they never did before and can become severe.  So folks that are confident they are immune,,, be careful.  You’re gifted but don't be over confident.  It really sucks when you get it bad, drives you absolutely nuts. /forums/images/graemlins/mad.gif
Anyway thanks folks for sharing your other remedies I might try some of them this summer.  I'm sure I'll have another chance. /forums/images/graemlins/mad.gif
