unable to reset tire bead on 13.6x38 tire
   / unable to reset tire bead on 13.6x38 tire #11
I would try lubing the rim, inflate the tire and worm the tire up. A heater and blanket should do it.
E/S
   / unable to reset tire bead on 13.6x38 tire #12
I see this thread is two years old but has been very helpful. :thumbsup: I have a 13.6 - 28 ag tire that has seated on the inside rim but about 2' of the outside rim will not. It is tubed. Have deflated and re-inflated several times to no avail. Cleaned the rim, sanded smooth and lubed with Bead Butter. No change in getting that portion to seat. I think my best bet is to use the tractor and wait for a really warm day. :). Todays high was 64 F.
   / unable to reset tire bead on 13.6x38 tire #13
yup.. if it is tubed. pump it up and run it around the pasture.. then deflate a lil. they usually seat.
squirt some tire lube in the crack and deflate nad inflate. sometimes that alone will seat them.
TANK MANIFOLD (A55745)
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
1997 Perkins 75KW Towable Diesel Generator (A56857)
1997 Perkins 75KW...
4 CYL ENGINE BLOCK & ENG STAND (A58374)
4 CYL ENGINE BLOCK...
2013 MACK CHU613 (A58214)
2013 MACK CHU613...
2007 Vantage P-42-1000 42ft. T/A Dry Bulk Pneumatic Tank Trailer (A55973)
2007 Vantage...
