under ground wire help
   / under ground wire help #1
jack707
Veteran Member
up North wisconsin
farm trac 555
I'm hooking up my outside boiler and the trenches are dug, but my question is what gauge of wire do I need? the OWB has 2 I want a cable with 3 so I can ground it to the frame.
   / under ground wire help #2
That will depend on the draw of whatever you are powering. What does the rating plate say on the boiler?
   / under ground wire help #3
My guesses:
Does it have a: Blower? (60-250 watts)
Solenoid for air? (10 watts)
A convenience light? (13-150 watts)
A receptacle (widely variably, call it 180 watts) That's a worst case of say 600 watts, which is 5 amps at 120 volts.
How far is boiler from panel?
For 5 amps a #12 gauge should be able to run a few hundred feet (others with can confirm) with under a 3% (3.6V) voltage drop.
You need to run a 3/c cable so that if your circuit ever shorts to the boiler, there's a low resistance path on the green wire back to the utility's transformer so that lots of current can short into the boiler and the breaker will trip.
   / under ground wire help #8
Well then I'm good at 95'
Depends on the amp draw.
Wire size is based on 2 things. Length, and amps. You have only provided 1 part.
I'll go with #12 that should be good enough to run the pumps and the light.
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
WB Mower (A50120)
WB Mower (A50120)
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
