Underground Air Line
   / Underground Air Line #21
You can tell CurlyDave has been around the block a few times. He is a practical thinker with lots of common sense. Great alternative suggestion Dave.
CurlyDave I think you win!! I'll run the power line thru the pipe and get a cheap compressor. I'm still going to run a drag line within the pipe as members recommended in case I want to pull something thru later.
Thanks all!!!!!!
   / Underground Air Line #24
Dougryan said:
Someone told me that you can tie thread (sewing thread) to a tissue and suck it through with a shop-vac, then use the thread to pull a heaver string through.
Doug
That will work. I had about 100 feet of underground conduit that I needed to pull electrical service entrance cable through. Tied contractor cord to a chunk of fiberglas insulation. Shop vac pulled it through fine.
1996 Monon 45X96 Dry Van Trailer (A52128)
1996 Monon 45X96...
1993 Mono Dump Trailer (A50514)
1993 Mono Dump...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
2002 NEW HOLLAND 4X4 TN75S TRACTOR (A51243)
2002 NEW HOLLAND...
2016 Freightliner Cascadia Tandem Axle Road Tractor (A47384)
2016 Freightliner...
