underground water lines, what size plumbing
   / underground water lines, what size plumbing
ok what would be a good way to ensure i get enough water to the other side? some type of meter?
   / underground water lines, what size plumbing #62
I think I would use a piece of soaker hose with an emitter around each tree. A couple of years to allow the roots to grow and establish and you could go back to your original plan.
Just saw this,
What do you mean?
   / underground water lines, what size plumbing #64
I typically use the perforated tubing or soaker hose and run it in a circle around the tree on the surface small trees may start out with a 4ft diameter circle and a good rule of thumb is a little less than the span of the tree to get to the end of the roots. You can pin down the tubing with some small wire loops if yo need to mow over it.
1R SILT FENCE PLOW (A52706)
1R SILT FENCE PLOW...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
Adams 6 Ton Hydraulic Lime Spreader (A55302)
Adams 6 Ton...
FORD COBRA REPLICA RACING CAR (A53426)
FORD COBRA REPLICA...
Two Pairs of 10ft Fork Extensions (A53421)
Two Pairs of 10ft...
2015 Genie GTH-636 Telehandler (A54865)
2015 Genie GTH-636...
