Unique building system introduced for post-frame construction
/ Unique building system introduced for post-frame construction #1
s219
Super Member
Virginia USA
Kubota L3200, Deere X380, Kubota RTV-X
This looks real interesting. They build the roof framing and attach the roofing metal while the roof system is close to the ground, resting on some large I beams that are connected to a hydraulic scissor lift. All the wall posts and girts are framed up and attached to the roof framing with hinges. Then they lift the roof into place vertically and the walls swing into place underneath. Pretty interesting.
Unique building system introduced for post-frame construction | Farm Progress
And here's a good video:
QLYFT Building System - YouTube
/ Unique building system introduced for post-frame construction #2
Fun seeing how they lifted the roof, but I wonder how much more money this method costs, and if it's built any faster then traditional pole barn construction. With what it must take to set everything up, and the greater effort to build the walls their way, it might take longer to build then traditional pole barn methods.
/ Unique building system introduced for post-frame construction #3
Amazing... I bet the pricing on that will leave a mark...
/ Unique building system introduced for post-frame construction #4
Will you be able to pull a pin,fold it down,patch and fold up again when it's needed?
/ Unique building system introduced for post-frame construction #5
A TBN member recently wrote about using this or something similar to put the roof on his pole barn.
2022 JCB 509-42F TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42F...
2023 GERINGHOFF PATRIOT RD8R30" CHOPPING CORN HEAD (A64278)
2023 GERINGHOFF...
16ft. T/A Utility Trailer (A64557)
16ft. T/A Utility...
JOHN DEERE 5510 TRACTOR (A64278)
JOHN DEERE 5510...
6' SCRAPE BLADE W/ SLIDE, 3PT (A64278)
6' SCRAPE BLADE W/...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
