Unknown function of lever(see pic)
   / Unknown function of lever(see pic)
Parking brake? diff lock?
It's not the diff. lock because I have a pedal on the left for that. Parking brake? I will have to try and see if that's what it is.
That's the donglemeyer overload protection lever. If you feel as though your donglemeyer is getting overloaded you throw the switch rapidly and repeatedly.
That makes sense, a donglemeyer overload protection lever, if that is the correct answere it will come in handy because my donglemeyer stays overloaded. I just wanted to make sure it wasn't the eject button and throw my *** off the tractor.....
To where is it connected? What moves when the switch moves?
It's connected to a rod that goes straight down into the transmission cavity. I don't know what it moves because I did not move it while the tractor was running.
Throttle tension?
Nope not the throttle tension, my throttle tension has a ball and spring located on the throttle lever and it's not adjustable, that I am aware of.
   / Unknown function of lever(see pic) #14
operators manual = have the details / explanation of what does what.
service manual = for tearing it apart and diagnosing issues.
might help taking a few other pictures, showing all the controls of tractor, so folks can eliminate various controls
If no one gets it right tonight, I will see if Hoye has a Operators manual. I will take more photos tomorrow. Thanks for all the replys, alorio1
   / Unknown function of lever(see pic) #17
The service manual / operators manual is for a US model 336. I don't believe the 336 had this feature
   / Unknown function of lever(see pic) #18
creeper lock out lever, if u try to shift into low gear it will feel difficult until you rotate the lever, never has to be moved, low gear is very slow
   / Unknown function of lever(see pic) #19
336d also has similar lever, similar location ..
Thanks Grainger for putting this to rest and to everyone who made suggestions..........so now we know. Alorio1
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2015 FREIGHTLINER CASCADIA(INOPERABLE) (A52472)
2015 FREIGHTLINER...
New/Unused 12ft x 7.4ft x 8.2ft Container (A51573)
New/Unused 12ft x...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2007 Hino 268 Truck, VIN # 5PVNE8JVX72S50442 (A51572)
2007 Hino 268...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
