Unloading 15 Gallons of Diesel
   / Unloading 15 Gallons of Diesel #11
<font color=blue>His system uses pulleys and such</font color=blue>
Actually, Roy, I never got around to rigging the pulleys, but you're probably remembering <A target="_blank" HREF=http://www.tractorbynet.com/forumfiles/47-128906-PouringDiesel.jpg>this picture</A> I posted a while back. I just hang it on a sling hook attached to the eves of the shop.
I use a couple of yellow 6-gallon cans that actually have "Diesel" embossed on the sides. That's about as much as I care to hoist by hand, and when I get tired of that I'll figure out something else. That's where the real fun is anyway.
   / Unloading 15 Gallons of Diesel #12
Thats a West Virginia credit card....
   / Unloading 15 Gallons of Diesel #13
If you have a set of forks you can strap it to a skid.
   / Unloading 15 Gallons of Diesel #15
You don't need to fill them full. I wanted a single 55 gallon barrel of diesel but instead picked up two barrels and filled them each with 25 gallons of OR diesel. 25 gallons in a steel barrel is light enough to work with and tip up from laying down on its side. I then pumped one barrel into the other with my 11$ harbor freight rotary pump, then moved the pump to the full barrel. I will add 25 gallons when I think the barrel is getting down. I saved 40 cents per gallon and the barrel is always ready for me to make a withdrawl.
Thanks, but I got my answer 4 years ago.
   / Unloading 15 Gallons of Diesel #17
But there have been so many advances in fuel delivery systems in the past 4 years. I bet that string attached to the garage door (a few posts back) has been upgraded to a rope.
Steven
   / Unloading 15 Gallons of Diesel #18
Yep, you could also go get two 2 by 6 laminated planks, and wheel'em up and down with your hand Dolly.
   / Unloading 15 Gallons of Diesel #19
Good! Because 4 years is a long time to drive around with containers of diesel in your pickup!
   / Unloading 15 Gallons of Diesel #20
Instead of fooling around with 2 55 gallon drums why not go with 1 and have the distribution fill it for you when they are in your area?
I have 1 or 2 distributors and a bulk plant here that will top off my drum whenever they are making deliveries in my area.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
1263 (A50490)
1263 (A50490)
LOT LOCATIONS (A54313)
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
