pclausen
Veteran Member
I'm having my cab frame replaced due to an incident that involved my GN trailer. I'm doing a lot of the labor myself, and I figured this would be a perfect opportunity to upgrade the stereo and speakers.
Here's a shot of the cab after removing the headliner:
Closeup showing the stereo connectors. The colorful one is for the Bluetooth mike (red arrow) and aux connector (yellow arrow). The black connector is for power and speakers. And then there is the antenna connector.
Here are some shots of the OEM 4x6 speakers:
Nothing to write home about for sure!
Here's where the right speaker is locate above the radio. The red arrow points to one of the mounting holes for the speaker.
Close up. The sound is almost 100% obscured by the radio!
The left speaker location is much better, but the sound still has to penetrate the headliner.
I should be able to plug the OEM mic into the female plug on the new stereo head unit, and I will also run a USB cable down to the right console so that I can connect my ipod via USB instead of the analog aux connection. This is the cable I plan to use which should make for a very OEM look. I plan to drill a whole, or use an existing hole for a flush mount.
Here's the radio I picked up:
I'm still trying to decide which 4x6 speakers to go with or perhaps pick up 6.5" speakers and use 4x6 to 6.5 adapters like these:
Well, that's pretty much it for now until I get tractor back from the shop with a new cab frame on it. Hopefully that will be by the end of next week!
