Redbug
Veteran Member
Google Earth and Bing maps do not help in preserving your privacy. Anyone can see what you have and plan a route into a place. Dogs, ditches and pipe gates are the best. Someone needs to be on the property to protect it.
			troutsqueezer said:Buy a clunker car or truck. Park it at the gate, facing the gate. Hook up a motion detector that works from the car batt. When triggered, the head lights come on for a few minutes or a car alarm triggers. If it is night time, the head lights should scare the crap out of them. Daytime, the alarm might be enough. Car horns are pretty loud.
This is a great idea. However if they are observing property over time ahead of the break in, they will catch on.
The lumber/forest companies up here mount a swinging 8"+ diameter thick pipe to a vertical support with another pipe going from horizontal pipe to post at an angle for support. This gate locks into another post via a locked pin. The pad lock in up inside a steel box(bottom open) you reach inside, unlock, remove lock and pull pin. The gate opens. The lock box is made from 1/2" plate and the pin is usually 1.5"+. I am no expert but I think the only way to get in with this set-up is to use oxy/acet torch. It is massive and the pipes are buried into a large and probably very deep concrete block on both points of ground contact.
Can you get a remote sensor that will turn on lights, radio(and or recording of a loud barking dog with random pattern) - in the house and barn/workshop before the idiots get there. This might slow them down. I would post as much as possible and use as much remote sensing units as you can afford. If it is a continual problem you may find your insurance rates going up... would try to put the money up front into protection.
I would also invite friends/relatives to use the place more often when you are not there and set up a random pattern of visitation. This will keep the idiots guessing...
Feel for ya - good luck.
A determined thief can and will get in to your property. You have two real solutions - get insurance for personal property and develop a plan for your wife and your personal defense while you are there. You will never keep out a determined thiefAnother vote for the horizontal pipe "forestry" gate. Its the standard here. Have it on my own cottage.
