Urgent Plumbing help neded.
   / Urgent Plumbing help neded. #11
Sharkbites are used in our automotive gas lines now , air lines in trucks and natural gas company's use them to repair gas lines when I OOp's them with the Bhoe. Clean all sharp edges on the pipe and lube it so the O ring gets no damage give a little tug to set the teeth and your good to go. I was skeptical a few yrs. ago but since then I've got over it.
   / Urgent Plumbing help neded. #12
Well, The ones used here for NG line repair ain't exactly shark bite fittings... The ones used here (in the US) are plastic and rated for NG. But, they act similar to shark bite/gator bite ,etc,
Just want to clear this up so, no one goes out and buys a shark bite fitting to repair a NG line and think it's safe
   / Urgent Plumbing help neded. #13
Thanks guys.
Under the house was a mix of galvanized and PVC. Galvanized was pretty clean inside. I did not need to thread any of the galvanized. Just had to cut it to get it out and then removed it at an existing joint. Used a Tiger Saw with a cheap but fine toothed metal blade. Went through it like butter. Had a very hard time getting the shower valve body and pipes out of the wall without damaging the sheet rock on the other side (of course it needs an access panel anyway but the kids had just painted that wall and didn't want one yet.) Screwed the brass fitting with a Pex barb into the galvanized joint and then connected it to the Pex. This little house is 60 years old, was not a high quality thing to begin with and has been endlessly bodged over the years. I did use the Sharkbite connectors in the wall. They may in fact fail one day but as it currently stands they are probably the safest connections in the house. Plus, there was so little room it would have been hard to get the crimp. I did crimp where ever I had room to do so. They will probably only be in this house for a few years.
In this area copper has problems with well water. It stains everything greenish blue and unless you have a good filter the sand and sediment in the water will wear it thin. We had three major in-the-wall and in-the ceiling leaks with copper pipes that were around 2o years old. You could literally collapse the pipe between your fingers.
Anyway, I want to thank you guys once again. You always come through for me when I need the right info and need it fast.
Are you using Type M or Type L or Type K for your copper lines.
As a rule... I always use Type L
   / Urgent Plumbing help neded. #14
Good point Ken but no problem they won't fit on NG lines and the NG company won't give me any :) darn so I have to pay for the repair.
I don't know. Had all copper pulled out and replaced with Pex. That was in my previous house. In current house, 85 year old family home, there is a mix of copper and Pex in basement and a little bit of galvanized still left in the walls. But, current house is on city water so no issues with copper here.
   / Urgent Plumbing help neded. #16
They will fit on the plastic ng lines... I was doing some plumbing work on a home, where a contractor doing some landscaping work,broke & repaired a 5/8 plastic ng line with a 1/2'' shark / gator bite fitting... I called the gas company to have them make proper repairs
2015 HINO CONVENTIONAL TYPE TRUCK (A52472)
2015 HINO...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2005 Ford F-350 4x4 Service Truck with Crane, VIN # 1FDWX37P55EB97537 (A51572)
2005 Ford F-350...
2009 Chevrolet Traverse LS SUV (A51694)
2009 Chevrolet...
2018 Ford F-150 Pickup Truck (A51692)
2018 Ford F-150...
