Used B7100's
   / Used B7100's #11
Re: Used B7100\'s
Chris,
What part of PA are you from? I've researched and looked at a ton of used Kabota, JD, Ford's etc. over the past 4 months. I travel a lot so I've see tractors from Pittsburgh out to Chambersburg/Harrisburg area. I can tell you from my experience that there is one Kubota dealer in particular (I won't name names here) that is outrageously priced compared to others. I wound up with an awesome deal after feeling like I would never find one. I bought a JD 770 (24hp) w/ 60in MMM, 500 EASY hours and still shiney like new for $7700. I mean this tractor looks like a 2000 model and it's an 89. It was garage kept, waxed, serviced, and cleaned after every mow. If this tractor had made it to a dealer it would have went for 10K easy. Some say that I was lucky which I don't deny, but I also turned over every stump in the state looking for this deal. Let me know if I can help. If you're anywhere in the Southwest to Southcentral part of the state I'd be glad to share my experiences with you.
   / Used B7100's
Re: Used B7100\'s
All,
Thanks for all the replies. I've decided to wait a bit, and continue shopping. There were 2 great sounding bargains in the local newspaper this week, but both sold before I could get to them. Very disapointing!
Briar, I am in South Central PA, just South of Harrisburg. I'd appreciate it if you could send me the name of the over-priced dealer via private mail. I want to make sure to at least be very cautious with them.
Thanks again,
--Chris
   / Used B7100's #13
Re: Used B7100\'s
chris: i found my tractor at this web site www.ironsolutions.com then click on search and check wat u want to look for. u may get lucky like i did . tractors are from all over the us, some have pics and details.found the one i bought 172 mi. from home, in butler pa. dealer delivered free. used b2400, 98, with 68 hrs on it . with fel,back blade and 5 ft. finish mower. check it out! can't hurt and gives u a good idea of prices in diff. parts of country.
   / Used B7100's #14
Re: Used B7100\'s
Frank
I'm just a little bit curious about the tractor you bought in Butler, Pa. Did it have a light green 3PH blade?
Bud
   / Used B7100's #15
Re: Used B7100\'s
bud yes it did , how did u know that? are u familar with the tractor? have had it since early feb. anything i should know?
   / Used B7100's #16
Re: Used B7100\'s
Frank Nothing at all wrong with that tractor, the owner traded it for a larger tractor. The reason I mentioned the blade was, it was mine at one time. That's where I bought my (B2400) tractor new in 1998, it now has 120 hrs on it. I just ordered a 352 loader without the valve from them. I'll put it on myself. I bought a pallet full of hydraulic components at an auction from a Kubota dealer going out of business. Amoung the stuff on the pallet was three joystick valves for a 351 loader, and one for a 680 loader. So the last thing I need is another valve.
If anyone is looking for a used B2400 there is one nearby with 220 hrs, and a 351 loader for $12,200. If you want it with the Kelley backhoe It's $16,500. That's before dickering.
Bud
   / Used B7100's #17
Re: Used B7100\'s
Bud
Is that B2400 the one that is at the dealer there in Butler? Are their any attachements with it (i.e. mower)? Anyway, I am looking at a B2400 now with a 351 loader and 4672 kubota backhoe for $15K with 600 hrs on it. Do you think that is a good price? How do you like your 2400?
   / Used B7100's
Re: Used B7100\'s
Frank,
Thanks for the URL. I'll check ironsolutions.com out.
--Chris
   / Used B7100's #19
Re: Used B7100\'s
Bud,
Anything else on that pallet that you would consider selling - like a 3-way open center valve? I would like to work my way toward a top n tilt solution, but start with the remote valve installation. Then I can use a power rake this fall as well.
PaulT
   / Used B7100's #20
Re: Used B7100\'s
Babybober Don't know the condition of the setup you are looking at, but this one is clean. This one has a Kubota 351 loader that will take a MMM. It has a B600 Kelley 3PH hoe, that will also make room for a MMM. Nothing else with it. Don't know if 380 hours would be worth $1500, then your setup may be worth more with a Kubota hoe.
The phone # is 724-452-8863 They are located just off I79 in Zelienople, Pa.
Bud
NEW Woods Reverse Rotation 5ft Tiller (A55218)
NEW Woods Reverse...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
BUSH HOG 2820 LOT NUMBER 125 (A53084)
BUSH HOG 2820 LOT...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A55788)
2016 Big Tex 14ft...
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
2010 MULTIQUIP 25KW GENERATOR (A53843)
2010 MULTIQUIP...
