kthompson
Elite Member
- Joined
- Sep 12, 2008
- Messages
- 3,509
- Location
- South Carolina
- Tractor
- Kubotas B2710, M6800, L6060 cab, Volvo EC excavator, 2 ZTRs and various implements.
I worked for a crane manufacturer for 10 years. In that time frame we built cranes for the Air Force and Marines. Memory wise unit was built structurally same as other units. Now could be different specs for engine or tires or such. Remember the Marine unit had mount for M16 in the cab. Things I can remember different was special paints used due to the use of one in water and it also had all electrical connects sealed with silicone sealant. But basically same machine as regular unit was except tweaked for their needs. If battery box is like the ones we had we used 12 volt batteries wires in series to get the 24 volts. Then all our units cranked on 24 volts.
Using crane with boom rotating and you sitting below it is not as good as one that rotates wit the boom but you will or should have clear view of about 180 degrees. I would have no issue buying a unit like that. Just do the normal checking the machine. Regardless of what type of machine you buy tipping is a major concern. Study proper operation. Move load low as possible to help prevent roll over, much like front end loader use.
