Used NH 630 round baler
   / Used NH 630 round baler #1
buckeyefarmer
Epic Contributor
MD
Kubota L3940 L5030 MF205-4 BX23
Guy down road has NH630, looks almost new,used on 10 acres last 20 yrs. Electric tie. What should I look out for?
I bought it, hope all is good with it.
   / Used NH 630 round baler #3
CV shaft is the biggest bill on them. Blew it on ours, was going to be $1000 for a new one. Don't have a CV joint anymore. IMG_0192.JPG
Check the belt splices, and check for hot bearings after you've run it a while.
There really isn't much to these balers.
Thanks.
didn't get the manual with it.
   / Used NH 630 round baler #5
Thanks.
I have the manual if you need anything that isn't easy to figure out. I ran it on 42 PTO HP for years and made hay fine, but have 64 PTO HP on it now and totally different machine.
   / Used NH 630 round baler #6
Thanks.
I've bought a number of old, equipment manuals on eBay. Also recommend a laser thermometer gun to check your bearing temps.
   / Used NH 630 round baler #7
CV shaft is the biggest bill on them. Blew it on ours, was going to be $1000 for a new one. Don't have a CV joint anymore.View attachment 505822
We sell a complete series 6 CV PTO shaft with a clutch for $625 delivered. A Series 4 CV is $100 less. We are not the only companies sin this price range. Dealers do not buy factor direct and can not compete buy from parts houses or through their Brand.
   / Used NH 630 round baler #8
It would have been nice to get a whole shaft for that, likely would have spent that easily, but I am in CDN $$$ so I should have stated that. Dealer wanted $1000 CDN for the front half, parts houses wanted $1000 CDN for the complete shaft, so they were still half price.
I assume bearings under each sprocket.
Never had or used a round baler.
I do have a laser thermometer.
   / Used NH 630 round baler #10
Given there is still paint on the chains I doubt you'll have bearing trouble, but yes, run the machine for a while and take temps, you can see if a bearing/roller is running hotter than others.
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
(6) Hole Punch Wheels (A57149)
(6) Hole Punch...
2004 Kubota R520 S (A57148)
2004 Kubota R520 S...
New/Unused Agrotk Tire Changer (A57454)
New/Unused Agrotk...
E-Z Trail 20' Head Cart (A59814)
E-Z Trail 20' Head...
2005 KOMATSU GALEO D39PX-21 CRAWLER DOZER (A52709)
2005 KOMATSU GALEO...
