Used PHD inspection
/ Used PHD inspection #1
sea2summit
Super Member
Left coast of, GA
Kubota 1860->25D, MX5800, M4D
Looking at used PHDs to use for a project then sell for at least close to what I paid. What are the critical things to look for/at before picking up a used PHD?
/ Used PHD inspection #2
How worn do the pins look, is it bent/been repaired, does the gear box hold lube and is it filled, is the auger heavily worn/worn out, too heavy of a shear pin (gr8 vs gr2 Or gr5.)
/ Used PHD inspection #3
If it's parked on stand for a length of time, check underneath it for oil spots. It can only leak in one of two places, at the input or output shaft on the gearbox. As mentioned, if it leaks, check the gearbox to see how much fluid is in it. Also, it would be ideal if the seller could hook it up to a tractor and spin it a few rpms so you can see if the auger (or the output shaft) might be bent, or if the PTO shaft might be bent. Lastly, since you have a Yanmar 2500, you might want to verify that the PHD will fit it well, and that it will lift it up high enough to keep from dragging the tip. Some smaller tractors have a little trouble with that part due to the geometry of the 3pt parts.
CASE INTERNATIONAL 3900 DISC HARROW (A63291)
CASE INTERNATIONAL...
2018 Western Star 4900 Tandem Dump (A62613)
2018 Western Star...
2014 Chevrolet Silverado Pickup Truck (A62613)
2014 Chevrolet...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
2005 Peterbilt 387 with Wet Kit (A63118)
2005 Peterbilt 387...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
