Used vs. New disc harrow? Smooth or Serated disc?
   / Used vs. New disc harrow? Smooth or Serated disc? #11
This is an easy decision. Go with the cheaper one because:
It is cheaper
The dealer stands behind it and its bearings.
It has scrapers.. you will find they are very necessary.
It is as wide, if not wider.
When a disk breaks... and it will... you can replace with serrated as they break.
And, like JoeinTX said, put weight on it... lots and lots of weight! Did I say weight it down??
Go across your field 3 times.
1st from side to side, long ways.
2nd at about a 30 degree angle to the first rows.
3rd at about a 30 degree angle from the opposite side.
Between each pass wait for the previous clods to dry out a little so that they shatter when you hit them on the next pass.
If it turns out that your tractor is insufficiently powered to pull the rig, you can remove disks until the horsepower matches the disk resistance.
Go for it!! /forums/images/graemlins/laugh.gif /forums/images/graemlins/grin.gif
Okay, I guess the consensus is that the used one is the way to go.
I'll probably go ahead and get it.
Thanks for the input!
   / Used vs. New disc harrow? Smooth or Serated disc? #14
Who makes the used one?
   / Used vs. New disc harrow? Smooth or Serated disc? #15
They weren't sure what brand they were.
You snooze, you lose. /forums/images/graemlins/frown.gif
I checked on the used disc on Friday and it was already sold.
   / Used vs. New disc harrow? Smooth or Serated disc? #20
</font><font color="blue" class="small">( You snooze, you lose. /forums/images/graemlins/frown.gif
I checked on the used disc on Friday and it was already sold. )</font>
See it was a good buy and someone else didn't hesitate.
Good luck next time /forums/images/graemlins/tongue.gif
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
2019 Komatsu PC490LC-11 Hydraulic Excavator (A49461)
2019 Komatsu...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
100 GAL FUEL TANK (A50854)
100 GAL FUEL TANK...
2020 Hitachi ZX60USB-5N (A47384)
2020 Hitachi...
