Using A 750 Gal. Tank for Domestic Water Use.
   / Using A 750 Gal. Tank for Domestic Water Use. #21
maybe I missed your point you are worried about holding water over the winter to use in the late summer??? Why not simply drain the tank for winter and fill it in the spring/summer before it dries up?
FYi I would use a much larger tank 1500/2500 gal new septic tank comes to mind, just pump it dry in the fall, cover. reopen and sanitize it before use. its just a homemade temporary cistern
2023 54ft Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54ft Hooklift...
Ingersoll-Rand SD70 (A47477)
Ingersoll-Rand...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56129)
2016 FREIGHTLINER...
ASCO Transfer Switch (A52377)
ASCO Transfer...
Giyi 27" Mixing Bucket (A53316)
Giyi 27" Mixing...
Miva Mini Excavator Attachment Set (A53316)
Miva Mini...
