using a pto pump to power a post driver instead of rear hydraulics
   / using a pto pump to power a post driver instead of rear hydraulics #1
forgottenben
I own a New Holland TC35d with a FEL but no rear hydraulics. It's at the end of it's life and I really don't feel like putting money into it to install rear hydraulics. I own a PTO hydraulic pump from Tractor supply and was wondering if I could use it to power the post post driver. The driver is a shaver pt8 model. I plan on upgrading tractors soon so I am looking for more of a temporary fix. Thanks
Ben
   / using a pto pump to power a post driver instead of rear hydraulics #2
I'd say powering the driver is not the problem, but rather on the drive stroke, having a place for the oil to dump in a hurry. Not sure what you have in mind for a reservoir, but if a smaller one, it would need to be vented well.
   / using a pto pump to power a post driver instead of rear hydraulics #3
I agree the return line would be the only thing I'd be concerned about.
Didn't some of those drivers used to come with a self contained PTO pump option? It would be worth a look to see how they did things.
what kind of reservoir? Do I need to fabricate something?
   / using a pto pump to power a post driver instead of rear hydraulics #5
You have to give the oil a place to go. On your tractor the oil returns to the transmission housing, on a PTO pump you need a tank.
   / using a pto pump to power a post driver instead of rear hydraulics #6
There is not very much fluid coming out of that cyl, and a 3/4 or 1 in hose should be sufficient between the driver and the tank.
Here are some tanks.
Surplus Center
   / using a pto pump to power a post driver instead of rear hydraulics #7
Much cheaper & easier to power the driver from the FEL valve and return the oil to the transmission fill port. Hundreds cheaper than a tank, lines, filter and your "free" pump.
   / using a pto pump to power a post driver instead of rear hydraulics #8
This is what you need to power the Shaver.
Hydraulic Requirements 3-4 GPM/1,500 PSI
You have the GPM, just add a relief valve.
If there is a valve on your Shaver, then adjust it to 1500 psi. and send the 3/4 in return directly to tank.
Since you have a FEL, then you may have a PB outlet. Just run the PB to the back and plug the Shaver into the PB QD.
Hose G20 , the return hose on the Shaver post pounder is only 3/4 in.
http://www.shavermfg.com/media/uploads/HD8-Operator-Manual.pdf
   / using a pto pump to power a post driver instead of rear hydraulics #9
   / using a pto pump to power a post driver instead of rear hydraulics #10
Before you go with a pto pump read Mounted Madness's thread about his experience and cost of mounting a post driver to his Kubota BX24.
I just read that post and the way he went about it makes no since what so ever.
I ended up at a local hydraulic shop and 3 days later, and $1600 lighter.... The hydraulic shop added a hydraulic motor powered by my BX24, that runs a hydraulic pump that powers the post driver...
WOW! :confused:
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
KOMATSU WA500-8 WHEEL LOADER (A60429)
KOMATSU WA500-8...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
Kubota L4701 (A53317)
