Using an easy out / bolt extractor
   / Using an easy out / bolt extractor #21
now that's funny. this thread needed a lil brevity. :)
soundguy
   / Using an easy out / bolt extractor #22
Hi -
From what I am understanding of your cutter, there are two purposes of the bolts. The first is to clamp the blades in place, and the second is to shear when force exceeds a certain threshold. I wonder about two things; 1) Are you keeping the blades shaped approximately the same shape (cutting edge, etc.) as the factory put on them; and 2) since clamping force of the bolts will change substantially (up to 25%) depending on whether the bolts are lubricated before they are torqued, are you lubing the threads?
I also wonder about having some large washers under the blade side of the bolt, in order to spread out the clamping force and increase the amount of friction on the blade since more of the blade would directly clamp to the blade adapters.
Lastly, if the blade adapters are now worn from the use / bolts shearing /etc., then they can be not providing the functionality in the blade retention that they should.
Just some thoughts, as usual, they are worth *every* penny that you paid for them ...
   / Using an easy out / bolt extractor #23
I wouldn't want the bolt holding the blade tot he pan to be the one to shear. i'd rather a pin in the driveline shear, or a slip clutch slip, vs making a high speed knife-missle out of one of them blades.. :(
soundguy
KUBOTA M9000 UTILITY SPECIAL TRACTOR (A59823)
KUBOTA M9000...
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
Informational Lot - Shipping (A56436)
Informational Lot...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
2018 Kubota U17 (A53317)
2018 Kubota U17...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
