Using Slime
   / Using Slime #1
MuncyBob
Platinum Member
N Central PA
PT 422
I have one wheel that has a slow air leak and have it looked at by 2 tire shops...nobody can seem to stop the leak, requires air into the tire about every 4 days or so. I was thinking about trying the Slime product but a friend said he thought the cold temps of zero or less that we sometimes get here would cause this stuff to harden and crack......anybody in cold temp areas have any experience with this or can suggest another solution? /forums/images/graemlins/confused.gif
   / Using Slime
   / Using Slime #5
I have it in every tire on my lawn tractors and the two fronts on my tractor. The stuff works great and no more flats. It gets below zero in Kansas during the winter and I haven't had any problems at all. Hope this helps.
   / Using Slime #6
   / Using Slime #7
Slime is great stuff depending on where the leak is. If it's in the tread, no problem it'll get it. Sidewall, you'll have to put the tire on it's side for a little while to guarantee the Slime gets to the hole. Same with a bead leak.
Just don't look to be too popular with your tire guy when it comes time to replace the tire or you get a hole too big for the Slime to plug.
   / Using Slime #8
   / Using Slime
I was going to have the tire guys tube it, but they said they can't due to 2 valve stems?
   / Using Slime
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
UNUSED JCT SKID STEER QUICK ATTACH 72" TILLER (A51244)
UNUSED JCT SKID...
Friesen 110 Seed Tender (A50515)
Friesen 110 Seed...
Kubota RTV 900 Side By Side (RUNS) (A50774)
Kubota RTV 900...
Kubota SVL95-2S Compact Track Loader Skid Steer (A50322)
Kubota SVL95-2S...
