utility trailer question
/ utility trailer question #11
if you are planning on moving dirt mulch ect, I would try & find a dump type trailer, there is a inexpensive you build it type that HOMIER sells for around 299 and holds 1 or 2 tons with 4 wheels turfs and had mand jack hyd cylinder to dump the load, built like everything else in china. I think it requires the user to build the box/deck as it is a frame & lift only thing plywood box of sometype to hold the load you will use.
it is similar to THIS one ebay
/forums/images/graemlins/crazy.gif
mark M
/ utility trailer question #12
Sigarms,
That looks liike a tough trailer, and pretty well suited for your described needs. The wire mesh sides will certainly come in handy --- but it will also limit "over the side" loading of things also.
If the price is right, I'd say "go for it"...
I didn't mean to hijack this thread...
/ utility trailer question #13
</font><font color="blue" class="small">( if you are planning on moving dirt mulch ect, I would try & find a dump type trailer, there is a inexpensive you build it type that HOMIER sells for around 299 and holds 1 or 2 tons with 4 wheels turfs and had mand jack hyd cylinder to dump the load, built like everything else in china. I think it requires the user to build the box/deck as it is a frame & lift only thing plywood box of sometype to hold the load you will use.
mark M )</font>
Thanks for those leads. The one on eBay looks like what I was thinking of...
I want something to pull with the tractor, and I can't back a 4-wheeled wagon...
Been there, done that, never did win the T-shirt. /forums/images/graemlins/frown.gif
/ utility trailer question #14
I have a 5' X 8' single axle trailer like that, I use it all over the place and it's handy as can be. One problem with it tho, you can't carry anything longer than the 8' cause you can't drive it with the tail gate down, but it's perfect for what I do with it. And 4'X8' stuff fits flat no problem........
I haul my ZTR with it from my country place to my house in town to mow, the ramp makes it easy to load. It also makes it a great trailer to move stuff with since it's so low and you can easily roll stuff up the tailgate......
You can only load it when it's hooked up to something, but I'm not sure I'd want to load any trailer unless it was hooked up solid to something........
/ utility trailer question #15
<font color="blue"> Is it realistic to think that I could use a tongue jack to hold the trailer while I load it with the FEL, then connect to the trailer to haul it to where I want to dump the load? </font>
Kent,
I think you will find that it is really a pain to hook up a loaded trailer. There are systems that you can buy that help to line up the hitch with the ball but I don't know how well they work. There are heavy duty ball mounts that pivot from side to side and angled brackets that line up the tongue with the ball as you back up. Trying to back the ball under the tongue is hard.
I have a Karavan aluminum trailer. It is sort of a compromise. It is 7x10. I don't need it to be so wide and I wish it was longer. I love that it doesn't rot or rust.It is nice that it is a little lighter than steel. My T100 will tow something like 5k and the trailer is rated to haul about 2500. pretty light duty. My Yanmar weighs about 1600. I can load the bush hog in the bed and the tractor on the trailer and the whole package tows easily.
Chris
/ utility trailer question #16
<font color="blue"> I can't back a 4-wheeled wagon... </font>
Me either! /forums/images/graemlins/shocked.gif But the truly amazing thing is that there are guys who can. /forums/images/graemlins/tongue.gif
Chris
Ended up getting the single axle 6'x12' couple of days ago.
No complaints, since its my first trailer of any sort, learning all the "fun" things about them, like backing them up and backing the truck up to it (I've learned already make the ground as level as possible). Hate to admit it, but also forgot to raise tha jack (not sure of propper name) ALL the way up (I thought it was /forums/images/graemlins/blush.gif) and had to go over a hill. BIG bump and a chunck of ground later, I learned my lesson.
Filled it twice yesterday with brush/trees. Wish I would of bought one last year when we first bought our new house. "Back then" I made a piece of plywood into a sled to haul things around that were to big to get into the truck bed. Wasn't pretty, but it worked.
Per yesterday, the trailer is worth every penny, only now I wished I got it sooner.
I will agree that after unloading the trailer twice, that a "dump" trailer may of been a better idea, but I do like the size I got and it can move my mower no problem.
/ utility trailer question #18
<font color="blue"> Anything to look out for or stay away from? </font>
I hate rust so I spent more for an aluminum trailer.
My Karavan has removable wood sides which does come in handy if you want to carry something bigger than the trailer like a shed or a gazebo.
Look at how the ramps work. On mine the ramp is full width and the slats are close enough that you can roll a small wheel machine on like my troybilt chipper/vac. The ramp folds up so I can't overhang the back unless I upbolt the ramp and load it in the bed. I have seen ramps that slide up under the floor of the trailer but I'm not sure what you do for a tailgate.
Trailer lights are a pain if someone had a better system It would be worth something to me.
Check out how you grease the hubs some/many trailers have a grease zerk on the outside but there are different systems and I'm not sure which is best.
There are different types of axles and springs.
There is an outfit called Champion trailer that sells trailer parts. It would be nice to have a trailer that had boat trailer parts which are somewhat corrosion resistant.
Chris
/ utility trailer question #19
</font><font color="blue" class="small">( I can't back a 4-wheeled wagon )</font>
Actually, it's not difficult at all; just takes a little practice.
/ utility trailer question #20
</font><font color="blue" class="small">( <font color="blue"> I can't back a 4-wheeled wagon... </font>
Chris )</font>
I had to learn how years ago. It was an oportunity to make some overtime, or go home early. If you go really, really slow and watch the front tires real closely, it will come together for you.
What's always impressed me is the guys who can back in a set of doubles!!!!!
Eddie
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
Kubota M4900 Utility Special (A60462)
Kubota M4900...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
