Utility Vehicle Bed Lift Capacity, Just curious.
   / Utility Vehicle Bed Lift Capacity, Just curious.
I had no doubt that a hydraulic machine would offer superior lift. Do the RTVs use a scissor type setup?
I am more curious about people with the electric/hydraulic units.
   / Utility Vehicle Bed Lift Capacity, Just curious. #12
My RTV 900 uses a single hydraulic cylinder similar to a commercial dump truck. The only time I have had it not dump was when I had it rounded up with rocks and one was wedged under the lip of a SS bracket dust guard that is attached to the roll bars (personal modification). I unloaded a few rocks and then tried it again and it just crushed the trapped rock, so yes it unloads about all that you can load on it with engine idling.
   / Utility Vehicle Bed Lift Capacity, Just curious. #13
The newer mules use an electric over hydraulic cylinder setup. I've been thinking about adding one soon, I believe they're rated for full bed capacity which is over 1k if memory serves.
Matt
   / Utility Vehicle Bed Lift Capacity, Just curious. #14
RTV-1100 have fully filled bed with heaped pea gravel and dumped every time with no problems.
David Kb7uns
   / Utility Vehicle Bed Lift Capacity, Just curious. #15
I have an '06 RTV900. If it will fit in the bed the hydraulics will dump it. Rocks, concrete, wood, dirt, hay rolls, limestone, whatever.
Good to know since I have one of those as well. Thanks,
   / Utility Vehicle Bed Lift Capacity, Just curious. #18
The RTV-X900 has a capacity of 1,100 lbs. Not sure what it actually can carry and dump, but I can say that my experience has been great. Always was able to handle the load I've placed in it and dumping is a breeze.
John Deere 9450 Combine (A50514)
John Deere 9450...
Ford 641 Workmaster (A50514)
Ford 641...
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
FRUITLAND VACUUM PUMP (A50854)
FRUITLAND VACUUM...
