muddstopper
Veteran Member
Go to your local auto parts store and buy a thread file. They are pretty cheap, heres one on zoro, Nicholson SAE Thread Restoring File, Specialty 33 7 | Zoro.com
That's going to be pretty useless for cleaning up female threads.Go to your local auto parts store and buy a thread file. They are pretty cheap, heres one on zoro, Nicholson SAE Thread Restoring File, Specialty 337 | Zoro.com
I need to clean and refurbish the threads on a diesel tank. There are 6 total holes needing cleaned mainly of rust etc.
I've tried a wire brush to no avail. Only thing I can think of is a tap... but the only taps I can find are online and for sale. While I don't believe anyone should forgo payment for their wares, I just can't stomach a $150 tap to clean out 6 holes. A literal 5 minute job.
Any thoughts? I've thought about getting a 2" nipple, cutting grooves vertically along the threads and using it... but I have no idea whether that will work at all. The metals are going to be roughly the same hardness... maybe even softer than the tank, with galvanized 2" pipe.
Any thoughts would be appreciated. I haven't been able to find a rental. Even Harbor Freight doesn't have one, at least that I can find. The cheapest I can find on Amazon is $88 and they are back-ordered for 2 months.
My goal is quick... I was going to take the tanks to a sandblaster/welder tomorrow evening and have him clean them up. I was removing old fittings this evening, and while there are a couple I can't remove, there are also a few that are acting almost 'cross-threaded' because the threads are so bad.
Some have a 4 sided rounded stinger on each end for internal threads.That's going to be pretty useless for cleaning up female threads.
Not the one you posted a link to.Some have a 4 sided rounded stinger on each end for internal threads.
Ok, I didn't go back to look who posed the link. The one linked was a external only one.OK. ... But I didnt post the link - or even look at it.
I have re-furbished female pipe threads by lubing up a sacrificial nipple with never-seize and screwing in and out, going just a little bit more every time, just like you would with a tap, but not as aggressive with each pass. Might wear out a nipple or two, but they are dirt cheap compared to a tap. You need to clean and re-apply never-seize fairly often. If you can start the nipple at all, this would probably work. Then use pipe dope when you assemble the final pieces. I have found pipe dope to work best if you apply, diss-assemble, re-apply and re-assemble.
Since the threads are not deformed - just rusty I think you can do fine with your grooved thread idea. ... 1st tho, use a toothbrush sized wire brush and Kroil round and round on the inside threads to soften and mobilize the rust. A couple cleanings like that and the threads should look much better. - Then screw in your grooved pipe , back and forth, while still using Kroil to emulsify the rust. Should clean up well. ... Then you can tighten in a regular pipe or plug, etc with antisieze on the threads to finish the reforming. A tap wouldve been spoiled anyway. Rust is pretty abrasive.
