Vickers CM11-N02R20D-21 control valve
   / Vickers CM11-N02R20D-21 control valve
Has the sway or tilt ever worked on this machine? Does it even try to move?
Yes, when I was looking at the machine before I bought it, with the 2X4's between the axle & frame, I hit the lever and it moved a bit to the side it is now leaning towards. When I got the machine to my lot I yanked out the 2X4's and as soon as I started the machine, it swayed to the right and stayed there. I could tell before I bought it that the engine was laboring due to the hydraulics pushing against the 2X4 on the RH side crushing the wood. That's when the prev owner told me all Pettibone's eventually do that. I figured I could fix it no problem, I assumed it was the control valve.
The engine is an IH UB-240, I did a compression check and got the following results:
From the front cylinder to the back:
1) 155 psi
2) 154 psi
3) 154 psi
4) 148 psi
5) 152 psi
6) 155 psi
The engine laboring is definitely from the hydraulics, the steering control unit whines extremely loudly. I didn't hear the tell-tale relief valve squeal however, just a whining from the SCU.
   / Vickers CM11-N02R20D-21 control valve #32
sounds like you will have to start tracing lines to confirm everything is connected properly. Anything from me at this point would be a total guess..
I would concentrate on the pressure line from the pump to the CM11 tilt valve & especially the tank line from this valve to the filter and reservoir. Would also double check to make sure the lines are connected to the correct ports on the valve.
May need to install a gauge in some different areas also to see what is happening where.
I suspect you have a couple days of head scratching in your future:thumbsup:
I was able to get the check valve out of the valve housing. (http://imgur.com/Njep3F5) So I guess that's not a problem, but as far as I understand it, the check valve is only for manual steering.
I was able to find the part number and serial number finally. (Imgur: The most awesome images on the Internet)
I'm in the process of fixing the cast iron parts I damaged with the acid, might have to make one of the parts new, oops.
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
UNUSED DEERE FAMILY AR500 3/8" STEEL SHOOTING TARG (A58376)
UNUSED DEERE...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
LOT: (1) Pallet of Chains (A59076)
LOT: (1) Pallet of...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
2018 CATERPILLAR 336F L (A58216)
2018 CATERPILLAR...
