Vickers V210-8-10-12 spec's Help!
   / Vickers V210-8-10-12 spec's Help! #1
mooseman214
Can any one help me out with spec's for this pump?
   / Vickers V210-8-10-12 spec's Help! #2
This pump is considered obsolete by Vickers but I have attached the spec sheet for it.
Roy
  • v210.pdf
Thanks oldnslo.
   / Vickers V210-8-10-12 spec's Help! #4
Can you reverse the rotation on these 200 series pumps?
   / Vickers V210-8-10-12 spec's Help! #5
How are you going to use the pump? Direct couple, side by side, belt and pulleys, etc? If for example if direct drive, then if the engine is turning CCW, then the pump should be turning CW. If using belt and pulleys, then the arrangement of the shafts can be manipulated to turn it in the direction stamped on the pump.
If side by side, then the pump can turn the same direction as the engine. If the pump has to turn opposite the engine, then the shafts will face each other, but off set.
Direction of engine or pump or motor, is determined by looking at the main shaft side of the engine.
   / Vickers V210-8-10-12 spec's Help! #6
Yes, Vane cartridge assy can be flipped over to reverse (arrow seen on outside of cam ring will show rotation)
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
Toro z turn (A56859)
Case 1840 Skidsteer (A59814)
Case 1840...
2018 New Holland C227 Compact Track Loader (A56438)
2018 New Holland...
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
