Vickers V210-8-10-12 spec's Help!
   / Vickers V210-8-10-12 spec's Help! #1
mooseman214
Can any one help me out with spec's for this pump?
   / Vickers V210-8-10-12 spec's Help! #2
This pump is considered obsolete by Vickers but I have attached the spec sheet for it.
Roy
  • v210.pdf
Thanks oldnslo.
   / Vickers V210-8-10-12 spec's Help! #4
Can you reverse the rotation on these 200 series pumps?
   / Vickers V210-8-10-12 spec's Help! #5
How are you going to use the pump? Direct couple, side by side, belt and pulleys, etc? If for example if direct drive, then if the engine is turning CCW, then the pump should be turning CW. If using belt and pulleys, then the arrangement of the shafts can be manipulated to turn it in the direction stamped on the pump.
If side by side, then the pump can turn the same direction as the engine. If the pump has to turn opposite the engine, then the shafts will face each other, but off set.
Direction of engine or pump or motor, is determined by looking at the main shaft side of the engine.
   / Vickers V210-8-10-12 spec's Help! #6
Yes, Vane cartridge assy can be flipped over to reverse (arrow seen on outside of cam ring will show rotation)
2003 Big Tex 10PI...
More info coming soon! (A56859)
More info coming...
UNKNOWN  20 FLATBED GOOSENECK (A58216)
UNKNOWN 20...
Deere 410L (A53317)
Deere 410L (A53317)
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
2018 Chevrolet Tahoe SUV (A59231)
2018 Chevrolet...
