hcallaway
Platinum Member
Drip edge and then the cover for the facia?
			Grace weathershield, GAF water n ice. All that stuff should be applied directly to the roof sheathing as shown by the manufacture.
Also the ledger board being attached to the house with "Ledger Locks" is perfectly fine. The problem i have with what i see on the house is that i did not see any type of flashing applied before the ledger board being attached. I don't call house wrap flashing. Also when using I-joist as you did on this house in the areas of decks/balconies the rim board needs to be an LVL. If they used the regular Rim board that looks like thick osb in the area the ledger board attaches it isn't worth sh*t. The ledger locks need something good to bite into in order to work. Even if you used bolts you shouldn't rely on the osb rim board holding everything up. Usually it is shown on the print for the floor system. Those are my 2 main concerns. Oh yeah tell the roofers next time to push down on the water/ice in the valleys, no need to leave it an 1" up in the air as you can see in the picture. It doesn't work when its left up in the air it needs to be adhered to the sheathing. Sorry if i come across the wrong way i do not mean to. I am also not nit picking. But when i see something wrong i will let you know. One is a safety issue that should be corrected. The flashing should also be added. If both the things i said are in fact in place and i couldn't see it in the pictures please disregard what i said. I look forward to following your build.
I appreciate the comments. Some of them make me go back and give it the second, third and maybe fifth look.
Not sure if you were saying the Weather Sheild and GAF Water N Ice were applied corrrectly or not?
There was flashing applied prior to the ledger board. I did not take any pictures. It looked like a roofing type material. It was not aluminum etc...
The rim board at the screened in porch was treated 2 x 12? All the other rim boards were the same system as the engineered trusses. Material was stamped with the same company.
I cannot really comment on the 1" gap in the valleys.
I can tell you that the house is going to have siding and they will skin the facia and it will extend under the shingles.
