EddieWalker
Epic Contributor
I'm in the planning stages of running electricity from my meter to my deer blind. Then from the deer blind, I'll want to run it to a building that I plan on building in a year or so. I'm still clearing trees for the building, but guess it will be 200 to 300 feet away from the deer blind. I'll want 200 amps for the building, when it's done. I'll also have natural gas at the building, so the electricity will be mostly used for the AC and lighting. No laundry or heating. The deer blind is going to have the bottom part converted into a bathroom so I can have outdoor weddings at my gazebo on my pond. I only need 20 amps there, but there it doesn't make any sense to go with a small line for now and then add a bigger line later on.
I did a quick search on load calculators and came up with 600 aluminum, which will give me a 3% drop over the 750 foot distance. Do I need to calculate the distance for the building at another 300 feet? Seems like I should since that's where it will be needed the most.
If this is accurate, then do I need two 600 aluminum lines for my hot lines? what would I use for my neutral line?
I have a 1,200 amp meter and so far I'm only using 600 amps on three breakers.
I really don't want to go above ground and I'm trying real hard to avoid another meter.
Thank you,
Eddie
Thank you,
Eddie
