wagner loader control need replacement
/ wagner loader control need replacement #1
woodywood
orting washington
ford 8n,9n farmall super A
where can i buy a replacement control valve for my WM3 wagner loader which is mounted on my 8N Ford tractor.My loader leaks down even with no load. the lift arms cyls are single acting and the bucket cyl is a double acting cyl.I have a lot of info about this loader but dont know where to get parts. the loader control is a two spool valve with no seals when I got the loader it worked ok but he control valve was sticky so i disassymbled irt and cleaned the crud out of it. this is when it started to leak down and has just gotten progressively worse. I use the loader a lot and need to repair it.Thank you
/ wagner loader control need replacement #4
Welcome to TractorByNet!
I moved your thread to the Attachments forum. :)
/ wagner loader control need replacement #5
It should be in the hydraulic section as it is a loader hyd valve.
2004 COMBILIFT CL30060LA45 FORKLIFT (A63276)
2004 COMBILIFT...
John Deere HX14 Rotary Cutter (A64047)
John Deere HX14...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
2019 MACK ANTHEM 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 MACK ANTHEM...
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59910)
2019 ISUZU NPR 4X2...
2013 John Deere 2623VT Vertical Tillage Tool (A63116)
2013 John Deere...
