wagner loader control need replacement
/ wagner loader control need replacement #1
woodywood
orting washington
ford 8n,9n farmall super A
where can i buy a replacement control valve for my WM3 wagner loader which is mounted on my 8N Ford tractor.My loader leaks down even with no load. the lift arms cyls are single acting and the bucket cyl is a double acting cyl.I have a lot of info about this loader but dont know where to get parts. the loader control is a two spool valve with no seals when I got the loader it worked ok but he control valve was sticky so i disassymbled irt and cleaned the crud out of it. this is when it started to leak down and has just gotten progressively worse. I use the loader a lot and need to repair it.Thank you
/ wagner loader control need replacement #4
Welcome to TractorByNet!
I moved your thread to the Attachments forum. :)
/ wagner loader control need replacement #5
It should be in the hydraulic section as it is a loader hyd valve.
Peterbilt 377 Semi-Truck (A63118)
Peterbilt 377...
17601CFL (A59228)
17601CFL (A59228)
2008 HINO 268 4X2 26FT NON CDL BOX TRUCK (A59910)
2008 HINO 268 4X2...
Mini Skid Steer Pallet Forks (A64047)
Mini Skid Steer...
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
