walco 3ph utility dump box
/ walco 3ph utility dump box #1
shrekbelly
guys,
i made a rfp on a walco dump box, models 495 (48"X48"X18") 290 lbs, and the model 395 (36"X36"X10") 120lbs to a kubota dealer.
he responded that the model 495 was to big to go on my bx1850. aside from the visual that a 48"X48" is a RATHER/VERY large platform box to have behind my tractor, anybody have an idea why he said that????
prices on these boxes are dear ($500.00 for the 395), don't know about the #495.
i don't know if the 395 will meet my needs as a carryall box doing property patrol/debris/tree limb hauling w/chain saws etc., etc.,
anybody see em laying about your favorite tractor dealer? thanks, shrekbelly
p.s. whereas, i don't actually have a wood workshop, i may set to buiding my own carry all, at the complete garage of an industrious friend.
/ walco 3ph utility dump box #2
I have the Walco 495 (48"X48"X18") and it's a very handy attachment on my machine. I am use to haul firewood and also as a counterweight for the FEL.
By loading a pallet into the box that is loaded with bricks and blocks, I will be able to quickly add or remove ballast - as soon as I get the TPH forks, that is.
I suspect the reason that the dealer recommended against the 4'x4' box is the distance that would put your load from the rear axle. You'd need to do a quick moment diagram to confirm this, taking into account wheelbase, CG location and any front weights or FEL. Unless you have some serious weight on the front I bet you'd be awful light on your steering.
One other thing to consider is that overhang wagging around back there (both it terms of length and width) does restrict your ability to maneuver in tight areas. Unless you really need the 4'x4' size for a particular reason, get the smaller box.
baby grand,
you're probably correct about the weight/c of g/rear axle. i was intending to use front weights additionally and/or weight in the fel.
i liked the idea of the bigger, deeper box. perhaps, neil messick could chime in? thanks, shrekbelly
gents,
i guess i must be more perplexed by this than i thought . . . how does one add and operate a 350 to 400 lb tiller on the back of a bx then? (of course,
front counterweight is mandatory). i can't imagine ever loading more than 200 lbs in the dump box shrekbelly
/ walco 3ph utility dump box #5
gents,
i guess i must be more perplexed by this than i thought . . .1* how does one add and operate a 350 to 400 lb tiller on the back of a bx then? (of course,
1* The front blade on my BX1500 counter balances the rear tiller.
true, i could mount the hd 60" blade as a counterbalance. . . . but i think, that might be a little to unwieldy when doing my dawn and dusk property WORK patrols. plus, i hate to admit it, i'm growing fond of the fel. shrekbelly.
/ walco 3ph utility dump box #7
gents,
Shrekbelly,
The CG of the 4'x4' box is a little over 24" aft of the lower link pins on the TPH. I think a tiller would be more like 7" to 9", so a big difference in lever arm length. But if you counterweight the front with the FEL, or maybe if you keep the load light as you suggested, then you should be fine. I typically have about 500 - 600 lbs of material in mine, plus the weight of the box itself puts a total of about 850 lb at the CG, pretty far from my rear axle. That's a fair tail load for my machine.
I'm glad topic came up, because I was wondering if anyone knows where a tractor owner can find out how much weight their tractor (without FEL) is supporting at each axle? I sort of guestimated a CG location a little aft of midway between the axles, but I'm not really confident that that's an accurate assumption.
-Jim
/ walco 3ph utility dump box #8
Well then put the FEl on and use it to haul that stuff with and ya would not really need the 3ph utility dump box .
. . . not so quick - LB . . . as your dual 1500's (don't know about the rest of your fleet) sit on the low side, so does my 1850.
from the seat, i'm able to reach to the turf with my magic, indespensible, clawed, trigger closing picker upper--to pick up the potentially hazardous sticks, limbs, branches, and golf balls in direct harms way to my mm mower deck, blades and their sharpness. i've got to pickem up sooner or later. the utility box gives me a reachable target to hit with one smooth wrist motion & and a good release. the fel is too small a target . . . yes, i've tried!
thanks for the feedback, shrekbelly
/ walco 3ph utility dump box #11
I just purchased the smaller Walco dump box for my BX1850. The size is very proportional for width, however the 36" depth seems to stick out a little more than what I would like. I did fashion some CubCadet wheel weights, 4 25# weights and brackets totaling about 125# for the front. I have been hauling firewood and dumping directly into my coal chute that leads to basement and have to say I love this thing. I don't know that I would load the box completely out to the end but the sides are high enough that I can stack quite a bit towards the tractor and some more pieces in the second row to get the weight correct to dump. Keep in mind, the smaller box does not have a tail gate but rather is angled up much like a wheel barrow. I also have a carry all that I built a box on that is 48" wide by 30" deep that I use for sticks and leaves and other things that aren't quite as heavey but take up more volume. I debated greatly before buying this and now am very happy that I did. I love the dump feature but be careful because there is no stop as to how far it will dump. I was thinking this weekend I may fab up a length of chain or something to regulate how far down the box will swing. I'm sorry I don't have the ability to take a picture but there was a post a while ago with a gentleman on a small Kubota to give you a scale of how big the box is.
2013 WINSTON AP22024AL-DC EQUIPMENT TRAILER (A66091)
2013 WINSTON...
Kohler Gasoline Air Compressor (A64553)
Kohler Gasoline...
2020 Freightliner CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 Freightliner...
2012 Chevrolet Colorado Crew Cab Pickup Truck (A64194)
2012 Chevrolet...
2025 Hercules 14 Gun Safe. (A64557)
2025 Hercules 14...
2022 EZ-GO ELITE...
