It’s difficult to say if the 2.0GHz would show a significant improvement in speed. Those numbers can be a little confusing, if not misleading, when doing comparisons. Desktops will always be faster than laptops, unless you have a desktop from 1995. Mainly because desktops have a high resource of wattage to spare. Most desktops come with a 400W+ power supply. Higher-end desktops have an 800W-1200W power supply. Laptops are anywhere from 65W to 95W. These numbers are overall consumption. Laptops, by design, are constantly giving up power to optimize battery life, even if it’s plugged in all the time. You’d really have to dig deep in the manual to find how much (min/max) voltage the cpu will take. Also, a higher frequency (1.5GHz -> 2.0GHz) is going to generate a lot more heat, which is not a good thing if it is on your lap.
Holly’s laptop should (by using advertised numbers) be equal to my desktop. Same AMD quad-core processor and 4gb ram, but my desktop can reboot twice in the time it takes her laptop to reboot once. And hers is newer.
If you want to download a free handy little tool that will show you all the crunch-numbers about your cpu, go to
CPU-Z CPUID - System & hardware benchmark, monitoring, reporting.
My processor has a max of 125W, but cpu-z reveals it’s sitting idle at 96W. So you can see a desktop’s processor alone is eating as much as an entire laptop.
Another thing to consider is cache. It’s memory built inside the processor, and it’s really a tiny amount. There’s L1, L2, and L3. This is rarely advertised, but is a primary factor in overall speed. All you ever hear about is frequency and number of cores. A dual-core processor (if it’s cache is high and balanced out), will perform as well as a quad-core processor (with ineffective cache). Balanced out means L1 total should equal L2, and L2 total should equal L3.
Mine has:
L1 data - 64KB (4x)
L1 instruction - 64KB (4x)
L2 - 512KB (4x)
L3 - 2048KB (or 2MB)
What’s funny is my first desktop didn’t even have 2MB of system ram.
Almost too many factors to consider when buying a custom PC. Goes much deeper than just saying you prefer Intel or AMD.
