waste oil burner
   / waste oil burner #21
Smart! I thought of something like that years ago but never quite got it formulated/implemented.
Mike
   / waste oil burner #22
Cliff, how's your stove? Any more tweeking?
   / waste oil burner #23
The only thing I've done is add a glass bottle gravity feed oiler. It's a gravity feed oiler that you would see on a lathe for oiling bearings or for oiling ways. I added it to my air tube so that water will drip into the path of the air stream. Which in turn adds oxygen to the burn and supports a cleaner burn. I had to play with the drip ratio to find the sweet spot. I found out by mistake that by adding a lot more water and by getting the burner chamber temperature up to about 1500 degree's. The water will clean the inside of the burner for me. Other than that, I haven't done anything else to it.
Note: Added a picture of a glass bottle gravity feed oiler that I put water in.
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
Caterpillar 2PD5000 5,000LB Diesel Warehouse Forklift (A53421)
Caterpillar...
Toro Mower (A50324)
Toro Mower (A50324)
2009 Pierce 105ft. Ladder T/A Fire Truck (A53422)
2009 Pierce 105ft...
