Pilot
Veteran Member
- Joined
- Nov 20, 2004
- Messages
- 1,208
- Location
- Oregon
- Tractor
- JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
Can't find the source of a water leak.
Furnace, water heater, well pressure tank and water treatment tank stand all in a row, close enough together that access between and behind them is limited. Furnace & water heater are propane fueled. Water heater is almost 5 years old, pressure tank 3 years. Water feed line is PVC running about 3" above the floor in front of the furnace and water heater--the routing is another story and not relevant.
I have maybe a 1/2 quart of water on the garage floor, mostly under the pressure tank, and the concrete blocks under the water heater are wet with mineral deposits for about 3" up. I found water on the PVC line, which is located below the fuel line and I found water on the flexible propane line to the water heater, which is the highest wet point above the floor. This flexible line is connected to a solid iron pipe which has no moisture. No water staining on the sheet rock on the ceiling.
Dried the PVC line and propane line and continue to get water from the propane line. How can that happen? I doubt that condensation on the line would put as much water on the floor as I am getting and the iron pipe is hardly cool.
Looking under the pressure tank with a flashlight, looking thru narrow slots, the plumbing connections look good, but that's about all I can see. They are the lowest spot of the tank except for the support ring. Water under there could easily have come from somewhere else.
To summarize: Highest wet area is the propane line. PVC line stays dry. Find no water when feeling around under water heater. Pressure tank & water heater are only a few years old.
Help!
Help!
