Water heater elements (as in wattage)
   / Water heater elements (as in wattage) #21
Using PEX has its advantages and very few disadvantages. Not all types use red and blue, some simply use clear. Some use brass fittings for tee's etc, others use all plastic. PEX can freeze and not break returning to its original size after thawing. PEX is not UV proof so cannot be used in direct sunlight. I wonder too if you have a rodent problem if they will chew the lines up, that could be a real issue. It won't corrode like copper when the water PH is acidic which can be typical with wells.
   / Water heater elements (as in wattage) #22
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2018 Ford F150 XL (A52384)
2018 Ford F150 XL...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
20711 (A50323)
20711 (A50323)
