Water heater elements (as in wattage)
   / Water heater elements (as in wattage) #21
Using PEX has its advantages and very few disadvantages. Not all types use red and blue, some simply use clear. Some use brass fittings for tee's etc, others use all plastic. PEX can freeze and not break returning to its original size after thawing. PEX is not UV proof so cannot be used in direct sunlight. I wonder too if you have a rodent problem if they will chew the lines up, that could be a real issue. It won't corrode like copper when the water PH is acidic which can be typical with wells.
   / Water heater elements (as in wattage) #22
7046 (A50322)
7046 (A50322)
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
Mini Skid Steer Sweeper Attachment (A51573)
Mini Skid Steer...
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52576)
2023 TAKE 3...
2014 FREIGHTLINER 108SD WITH ELLIOT H110 CRANE/MANLIFT (A52472)
2014 FREIGHTLINER...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A52748)
2023 NEW HOLLAND...
