Water in my crawl space: how best to drain it?
   / Water in my crawl space: how best to drain it?
</font><font color="blue" class="small">( InvesterGuy,
Two points;
I still have not seen any reply with regards to elevation. Do you have any area on your property that is below the footer?? You can use a lazer level and go in steps of the limit of the level. Or, setup a step ladder in an area you suspect is lowest. Place a 4' level near the top step catching the paint tray devise. Point this back at the house. Level the level. Now look down the top of the level like a gun site. Note the point where it intersecs the house/grade near the house. Compare the distance at the step ladder to the distance at the house.
Second, with your foundation having that wood wall sitting on the footer?? I don't see how you could fill any. You are with in inches of wood and dirt/water. Descride that wood wall, what's going on on the other side of it? because it either above grade or below.
Answer these two questions and your solution will come alot quicker. )</font>
First one, yes, I do. There's a ditch about 225 feet away from the house that the current footing drain runs into. There is a steady downward slope to the yard in front of my house out to the ditch.
Second one, you are correct. That wood wall would likely have to come up at some point. The water is probably 3 inches from it at this point, and the water level stays constant throughout the wet season, or at least whenever I've checked it. My father in law said that the real fix would be to jack up the house, tear out that wall (it's actually a double wall, about about 3 feet apart that runs the span of the house), and build up the cement a foot or so before buildign it back up. That sure doesn't sound too fun, but he says it wouldn't be that bad.
I tried calling the person we bought the house from but their # had changed. I will try to get the # of the builder from the county permit office, see what I can find there.
   / Water in my crawl space: how best to drain it? #42
"My father in law said that the real fix would be to jack up the house, tear out that wall (it's actually a double wall, about about 3 feet apart that runs the span of the house), and build up the cement a foot or so before buildign it back up."
Oh boy, that isn't the way I would do it. You just build another wall right beside the original starting with concrete at the proper height above grade. If the location of the original wall was somehow very important to the joists above, then a temporary wall or two can be built to support the floor while you rebuild the original wall.
   / Water in my crawl space: how best to drain it? #43
Both Paddy and Eddie have very good points.
Ideally you would dig a perimiter drain around the house and have it drain to a point lower then your footing, that's how my house is set up. This could be expensive and time consuming but the best option. IMHO filling your crawl space with gravel etc. is not a solution.
I had a similar problem with my daughters house (a year after she bought it), what we did is to dig a trench inside the basement around the peremiter of the foundation about a foot deep into this we place PVC drain pipe and covered it with pea stone and vapor barrier. At one end of the crawl space we dug a hole approx. 2.5-3 ft deep 2x2 ft wide and lined it with brick the drain pipe ended there opened. This served as a sump into which we placed a sump pump. During wet season the pump works frequently but their basement is dry (the bigger the sump the less frequentLY the sump pump will cycle).
Several comments: Down spouts from rain gutters should be set up to divert water well away from your foundation. Mold and mildew is a real problem, fungal infestation of wood can be disasterous. Not a bad idea to vent you crawl space if you're not already doing that.
Not an architect or pro just my 2 cents and good luck,
HankC
   / Water in my crawl space: how best to drain it? #44
OK, good so far.
Either your perimiter drain or the drain pipe is not working. Or both /forums/images/graemlins/confused.gif
I know 225' sounds like a longway but a trencher would have you a trench in 4hr for about $200. This time use 6" ridgid, that corigated stuff is tough to use where your grade drop is so slight, 5-6' in 225'. Make sure this one starts at or below footer height. In the trench at the house, check to see what kind of perimiter drain you have. Is at the bottom?? Filled with mud?? If it's junk, I'm afaid you will need to replace it. This time use mostly gravel to back fill, all but say the top foot. Use gravel rated for drainage. I'v seen chip & dust use and it holds water like a pond!.
This is a sure way of a good flowing silt free perimeter drain
From inside the crawl and all a long the walls dig a small 3" trench sloping so that all leads to the point where the new drain pipe is on the other side of the wall. Drill a 1" hole to drain the crawl or beter yet dig under the footer.
Good luck
   / Water in my crawl space: how best to drain it? #45
You could support the wall temporairily. You then drill and epoxy rebar into the footer. You then set a row of cinder blocks on the rebar and grouth them. You can then rebuild your wall on top of the blocks.
Ron
   / Water in my crawl space: how best to drain it? #46
Ronbo,
You got it. No one said this wall needs to be completely removed and then rebuild. I would take on a 4' section at a time. A hydro floor jack and a laminated set of 4x4 would catch a few joists and allow for 2 or 3 concret blocks in the row, 2 cources high. Then let it set a day. A few treated shims to take the load and "move over a few feet. Take a break any time! This wall was build this way to skip a beam/pier. Notice the joists direction. A bit sleazy in the construction world. A beams and piers could be put in but then your temp suport would e bit longer, say 10-12' depending how many 2x12 you use.
I don't want to scare InvesterGuy. This is really just simple grunt stuff, trench/perimter drain and replace the wood wall. If you plan to live there awhile it's the only thing to do. If you plan to sell in 2-3 years, sump pump.
   / Water in my crawl space: how best to drain it? #47
We see alot of these pony walls in crawl spaces up here under newer construction supporting long engineered joist spans. It is cheaper than sending actual beams down there. My 1999 home was one of the last I have seen with actual 4x4 posts supporting 4x8 beams. I like the post and beams better for ease of moving around in the crawl.
   / Water in my crawl space: how best to drain it? #48
I know he doesn't want to cob the job any but we should start simple and evolve into complex situations later. If he built the house he must have prints someplace. The prints would tell him if drains are inside and outside the footings.
Where do the downspouts go. In the pictures they seem to go underground somewhere. If this is the case then you need to get them going away from the house.
A sump pump and such is a low cost beginning. A few hundred and away you go.
If this fails you can get a ditch digger and reroute drains to the ditch. Again a little more cost but a possibility none the less.
Raising the house, pouring walls, footers and the like to me seems extreme until everything else fails. Ventilation is key and it seems the crawl has a bunch from the pictures.
   / Water in my crawl space: how best to drain it? #49
</font><font color="blue" class="small">( I know he doesn't want to cob the job any but we should start simple and evolve into complex situations later.
Raising the house, pouring walls, footers and the like to me seems extreme until everything else fails. Ventilation is key and it seems the crawl has a bunch from the pictures. )</font>
I agree with this statement allot.
Why rebuild the foundation when there's nothing wrong with it? We're getting away from the problem here and focusing on the wall. If it's solid concrete, there's still the problem of water in the crawlspace.
He has only one goal here. Get rid of the water. Anything else is a distraction. Focus on the problem.
WATER IN THE CRAWLSPACE.
Why is it there?
How to stop it, or minimize it?
What to do with what gets in there?
Eddie
   / Water in my crawl space: how best to drain it? #50
I think that Eddie's logic is clear.
Beyond that, are there no disclosure laws in your locale. This seems like a problem that should have been disclosed up-front to any prospective buyer.
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
2010 Hyundai Elantra Touring Sedan (A54815)
2010 Hyundai...
2010 MULTIQUIP 25KW GENERATOR (A53843)
2010 MULTIQUIP...
2018 HINO 268 REFRIGERATED BOX TRUCK (A54756)
2018 HINO 268...
2005 Chevrolet Impala Sedan (A55758)
2005 Chevrolet...
