Water in tank?
   / Water in tank?
Does your tractor have a fuel/water separator on it? Or is it just the filter? In my case, I can look through the side glass on my fuel/water separator and visually see if there's any water in it.
Just the two in-line filters.
   / Water in tank? #12
Sounds like the safety cut-off switch under the seat. I disabled mine. When pressing down the reverse pedal, you can take too much weight off the seat and it shuts off engine.
   / Water in tank? #14
I agree, this is most likely the issue. Happens to me all the time.
   / Water in tank? #15
Safety Cutout, Rust Clogging Filter and a pinhole in my rubber fuel line from a branch that worked its way to it...
All 3 have caused intermittent issues for me... but none in the first 20 hours except becoming familiar with the safety cutout.
   / Water in tank?
Thanks, I could see how this could actually cause my issue. I'll experiment and see if I can verify.
2013 Husqvarna LGT2654 54in Riding Mower (A55853)
2013 Husqvarna...
2011 SHOP BUILT FLARE STACK (A53843)
2011 SHOP BUILT...
1996 Parker Trailers TravAlong T/A Gooseneck Livestock Trailer (A55787)
1996 Parker...
Harris Kayot Boat with T/A Boat Trailer (A55853)
Harris Kayot Boat...
KMC 5610 (A53084)
KMC 5610 (A53084)
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
