Water Line Help for 1500' run from Spring to Homestead
   / Water Line Help for 1500' run from Spring to Homestead #31
I used black polyflex for a couple hundred feet. Home Depot stuff. Middle grade of three they had. I think choices were 120, 160, and 200psi. Even though your pressure is low enough I chose to go heavier (160psi) just so it didn't get crushed or damaged from rock fill or land shift whatever. I like your idea of the copper wire but that will cost you a few pennies I would think. But if you don't have any above ground reference then probably a real good idea. I did use brass fittings. Not a strong believer in using plastic valves/fittings but I do use schedule 80 stuff for some projects... like large salt water aquarium plumbing. Double clamping suggestion was a good one too. I noticed some trouble with using single hose clamps and getting them tight enough on my last install plumbing my green house with the black poly 1in.
   / Water Line Help for 1500' run from Spring to Homestead #32
They're just made a lot better and operate smooth as silk. I used some cheaper brand from TSC a few years ago and my dad used some Orschelins. Guess what, all 6 have had to be replaced with Merrills.
Merrill Hm-m? Any experience with Woodford? We replaced all our Clayton-Mark hydrants with the Woodford and have seen an end to troubles. One still orig hydrant I cant find a name because its in a nook in the barn. Hope that one doesnt go bad - itll be difficult.
...Ill keep Merrill in mind.
larry
   / Water Line Help for 1500' run from Spring to Homestead #33
www.cresline.com
These folks make all types of plastic pipe. Their website isn't exciting, but has several useful PDF files with specifications.
Honda EU3000is Gasoline Companion Inverter Generators (A54811)
Honda EU3000is...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
