747driver
Veteran Member
Hello 747driver. I would suggest that you run the bore to a 5000 gal tank so that WHEN, not if , the pump stops you will still have house water while the bore pump is being repaired. I would also recommend that the toilet be on bore supply so that the water absence is noticed quickly. On mine the bore supplied the stock water as well.
Not sure what you mean by 'bore' ? Would this 5000 gal. tank also be considered a 'cistern' ? If by saying 'bore' you mean running a separate supply line off of the main line to the 5000 gal tank ? That great advice by the way...thanks !
