WD-40
   / WD-40 #1
WVBill
Usa
Sold my Kubota B6100 when I moved to WA
At both Farm & Fleet and Tractor Supply, I've seen 5 gallon pails of WD-40. Now I use WD 40 in the spray cans for various things. Those small cans seem to last me forever. What would someone use 5 GALLONS of WD 40 for???
Just Curious.
   / WD-40 #2
Bill,
I don't buy the 5 gallons pails but I buy the 2.5 gallon ones. I just put it in spray bottles. I was always breaking or losing the spray tip on the cans. Plus the 2.5 gallons last forever and it's about the price of three cans of the regular. So mostly I just did it for cost and convenience.
   / WD-40 #3
Bill, I've wondered the same thing - for individuals. I just use the little aerosol cans, but when I went to Anchorage and worked with my brothers one summer in their tire dealership and garage, they bought the WD-40 in 5 gallon cans and used a lot of it; mostly a shot of it on corroded nuts and bolts before removing them.
Bird
   / WD-40 #6
John,
Bird beat you to the trivia around January..
Wonder Dissovlet...and the 40 means was perfected on the 40th try.
Thomas..NH /w3tcompact/icons/wink.gif
   / WD-40 #7
WVBill,
I've purchased the one gallon cans with spray bottle at CT before. Used it to clean off oil and dissolve grease on engines and tools, and soak rusty ol' parts. Used it to wipe down machinery that's stored outside. Clean out funnels after an oil change. Works good on aluminum. Alot of cleaner/degreasers aren't suitable for aluminum and doesn't seem to harm most paint or rubber either. That's a problem with a lot of the tri-chlor degreasers. That's a few I can I think of./w3tcompact/icons/smile.gif
DFB
   / WD-40 #8
DFB,
Ever try WD40 on your bike also good after welding joint.
   / WD-40 #9
<font color=blue>Ever try WD40 on your bike</font color=blue>
Nope. The stuff "goes away" too fast. Years ago I started using Tri-flow on the bike 'cause the stuff's so slippery and sticks around. Problem was that it also attracts dirt and stuff. Made a mess to clean up.
About a year ago I started using some stuff called "White Lightning". This is almost as slippery but it uses a parafin carrier. The nice thing is that when it dries, it really is dry, and doesn't seem to attract as much dirt.
Sunday I was doing a road ride (bikes) with a buddy and he brought out some stuff he called "Pro Lube", which is more slippery than White Lightning, but still doesn't attract gunk like Tri-Flow does. He also showed me a bottle of "Super Tri-Flow" that he'd just gotten. Have no comments on that, as I haven't seen it in use.
As for WD-40; one spray can of that stuff lasts for years. In fact, the propellant usually goes away before the can is empty. I can't even imagine using a gallon of the stuff! /w3tcompact/icons/shocked.gif
However, reading this forum is always an education /w3tcompact/icons/cool.gif !!!
The GlueGuy
   / WD-40 #10
Allright GlueGuy, another cyclist on this board!
I use WD-40 to clean my bikes and bike parts but not as a lube. You're right, it doesn't stick around long enough. I've been using Pedros Ice Wax on my chains for a couple of years and it works well. Similar to White Lightning, but a bit thicker. Seems to last longer between applications.
Good to hear you got out Sunday. I'm so sick of my basement walls I'm riding to work tomorrow no matter what it's doing outside /w3tcompact/icons/smile.gif
   / WD-40 #11
Thomas, WD-40 good stuff for sure. Used a lot of WD cleaning up the Zunny. Check out the pics. Before and after. (BTW the after was up at Gunstock for Vintage Race Day.)
One of the least things I do with it is use it as a lubricant. I usually use Zep 45 or tri-flow. There's also another spray I use has TEFLON in it. Can't recall the name right now.
Don't really find a need to use it on the H-D's. I use S100 Corrosion protectant on the metal/paint/plastic for storage. Other than greasing zerk fittings, wheel, swingarm and neck bearings, the cables are about it. I use a powdered graphite for the speedometer. One has a Kevlar belt, the other a pre lubed O-ring chain and I've used a parrifin wax chain lube for years after a few episodes of flinging oil up on the back/w3tcompact/icons/blush.gif of a certain p-pad rider./w3tcompact/icons/smile.gif
DFB
   / WD-40 #12
Beautiful job you've done on that little bike? Is that a 250cc?
Bird
   / WD-40 #13
You know... somehow I just knew Bird would know that... don't ask me why? /w3tcompact/icons/smile.gif
{from web}
WD-40 literally stands for Water Displacement, 40th attempt. That's the name straight out of the lab book used by the chemist who developed WD-40 back in 1953. The chemist, Norm Larsen, was attempting to concoct a formula to prevent corrosion-a task which is done by displacing water. Norm's persistence paid off when he perfected the formula on his 40th try.
   / WD-40 #14
Thanks Bird. That one is the 200cc Challenger model. the 250 was the Super Sabre. A lot of the parts are the same. There is a side panel that covers up battery and airfilter/carb asy. Has fully enclosed rear chain guard on it too.
DFB
   / WD-40 #15
<font color=blue>another cyclist on this board! </font color=blue>
Allright! /w3tcompact/icons/laugh.gif I imagine it's a bit difficult for you this time of year. Us too, but not to the same degree. Main issue is the rain & my fear of getting hit by a wild motorist (who all seem to be blind to bikes)! The trails are also in deep-mud mode, so I haven't been getting out on the Mt-bike much either /w3tcompact/icons/frown.gif.
That's all changing now. We are in full-blown spring-spinging mode out here /w3tcompact/icons/smile.gif, and I expect to get a lot of both road time & trail time. /w3tcompact/icons/smile.gif /w3tcompact/icons/smile.gif /w3tcompact/icons/smile.gif
My buddie & I are signing up for several "metric centuries" this spring and early summer. Plus, we are also seriously considering doing the "24 hours of Adrenalin" down at Laguna Seca this spring. It's a 24-hour mt. bike "race". Not exactly a race, more of a confirmation of idiocy./w3tcompact/icons/crazy.gif./w3tcompact/icons/crazy.gif./w3tcompact/icons/crazy.gif.
The GlueGuy
   / WD-40 #16
Re: WD-40/Bikes
<font color=blue>Not exactly a race, more of a confirmation of idiocy</font color=blue>
I almost got drug into one of those last year... 24 hours of Canaan in Viginia (or West Virginia?). The guys who ended up doing it had a blast and said it was more of a party than a race.
Yeah, our weather has basically su**ed this year. Not enough snow for tractoring and generally too lousy for biking. I did manage to ride into work today for the first time since November. It was 32 degrees but it's up to 48 now. Supposed to rain tomorrow and turn to snow again Friday /w3tcompact/icons/frown.gif
Do you ever get the feeling tractors and bikes are at opposite ends of some spectrum? Keep spinning and good luck with those centuries /w3tcompact/icons/smile.gif
   / WD-40 #17
Re: WD-40/Bikes
<font color=blue>Do you ever get the feeling tractors and bikes are at opposite ends of some spectrum?</font color=blue>
I would have to imagine some sort of multi-dimensional spectrum to make it work. But yes... About the only thing they have in common is wheels. Try to imagine the way you would compare all the different wheeled-things. Bikes & tractors, and cars, and trucks, and so on and so on.... makes the mind boggle./w3tcompact/icons/crazy.gif
The GlueGuy
   / WD-40 #18
Re: WD-40/Bikes
My bikes (bicycles, the Harley should be at the dealer next month) and my tractor seem to me to be at about the same end of the spectrum. I am into old bikes, pre index shifting and titanium and carbon fiber. My oldest is a 1933 Colson Flier (made in Eleria Ohio, I went there once but nobody knew where the old Colson factory was), and I have, if I can keep them straight, a 1955, 1959, 1963, two 1966's, 1968, and 1972 Schwinns. All are old fashioned one speeds, except the 1972 which is a 10 speed Continental which is original right down to the air in its tires! These bikes, and tractors, are really built of the same philosophy - simple design, ease of owner maintanance, interchangability of parts, and general respect for durability and quality of construction. One difference though - I can take my bikes apart down to the last bolt and bearing, and then get it back together again with no "extra" pieces left over. Don't think I could do that with the tractor yet, but I am trying to learn!
   / WD-40 #19
Re: WD-40/Bikes
GlueGuy and PaulB, I agree on the similarities (wheels) but for me that's about it. Weight is king on my tractor and if I could afford more I'd do it (loaded tires/wheel weights etc.). On my bikes it's completely the opposite. I spend money to keep weight off. On the bike I'm trying to go as fast as I can for my available power while on the tractor I often go as slow as possible while still putting out lots of PTO power. An interesting contrast that I don't lose sleep over /w3tcompact/icons/laugh.gif
Both fun activites and I'm glad to find others with similar interests /w3tcompact/icons/smile.gif
   / WD-40 #20
WVBILL ,I would buy a 5 gal bucket! As a matter of fact I use so much WD-40 I should have stock in the co. Its a wonder liquid, I mainly use it for my motorcycles to clean ,I will wash my bike and spray the whole thing down to wick the water away , and I dont use any engine gunk, I just spray and wipe everything .It does wonders for plastic and vinal, try this, if you have any plastic or vinal that sees some wear and gets set in dirt and looks discolored, spray some on, let set for a few seconds than rub with a towel ,don't wipe rub, it will take it out. I get under my truck and just start spraying , not only will it help protect the metal but it will loosen any dirt or grease to be wiped away. That is how I will clean my tractor also, wash the body with soap and water , than spray the undercarrage or motor/trans with WD-40 and wipe. Try it , go to the back of your tractor on the rear axle or the trans housing dont even clean it just spray the dirt than wipe away it saves me alot of time . If you like things clean and protected at the same time it easy. /w3tcompact/icons/smile.gif
JCB 507-42 TELESCOPIC FORKLIFT (A60429)
JCB 507-42...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
2015 BMW 328i Sedan (A59231)
2015 BMW 328i...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
