Escavader,
Yes. The Stove stank "wicked" when I burned the first normal fire. Pew! And the new paint smoked a tad, which is good, because it tested most of the smoke alarms in the house, which is good, because that tells me which rooms will get the heat, too.
After the 2nd normal fire, there was no more stink.
Dozernut,
I checked with my insurance company. They added me to the policy for $25.00 a year and I had to provide the paperwork from the installer.
3RRL,
Never had one before, but helped my in-laws many times with their's over the last 20 years, so I know what I am getting myself in to.
Egon,
Yep, it has an ash pan built in to the pedestal. Pretty nice. Just brush the ashes into the little hole in the floor, pull and turn the lever underneath and they drop in. When you pull the ash pan out, it has a lid built into it, so you just flip it closed (slowly or you'll get dusted, according to the salesman) and carry it out to the garden to dump. Nice feature.
WayneB,
My floor joists run N-S, my ceiling joists run E-W, as do the roof rafters, so all they did was locate where the pipe comes up from the basement and shoot a nail straight up through the floor centered between two joists and the proper distance from the wall for the chimney support box to go. It sits between the floor joists. Then they plumb bobbed up to the ceiling and shot a nail up through to the attic, plumb bobbed up to the roof. Once they had that line, they adjusted until they could find a happy spot centered between all framing members. None had to be cut and we required no angles from floor to rooftop. Nice, straight 17' chimney. They used two 45s in the basement to get the stove away from the wall. I'll photo document everything before I frame in the chase for the chimney that went through the first floor. May be a few weeks.
Mikim,
It directs the heat forward on its own more than upward. So I put a small fan on the floor and that sent some heat to the other half of the basement. Worked fine, so I will wait quite a while and experiment more before deciding on the factory blower.
Egon again,
I will gain weight because I have to eat donuts while gathering firewood.
SnowRidge,
You know me too well.
I would like to go the PT425 log splitter route, but my in-laws have a really nice splitter and they and my spouse would probably slap me silly if I spent any money on something the family already has. Most likely, I will go the hand splitting route... see my donuts comment to Egon above.
