Weather Stations? Anyone have one on the farm?
   / Weather Stations? Anyone have one on the farm? #11
I have the Davis Vantage Pro on my place. So far it has been pretty neat being able to look at the data it collects.
   / Weather Stations? Anyone have one on the farm? #12
I will try not to derail the thread here, but I had a question... I have been considering a weather station, and the best place (I think) to mount it and be open in all directions is the antenna tower attached to my house. Would it be better to attach it closer to the ground, or 30' in the air for accurate wind speed? If I mount it too low, it may be affected by turbulance from the roof, but higher up may not be an accurate ground wind speed right? or is 30' not enough to make a difference?
   / Weather Stations? Anyone have one on the farm? #13
I've got an Oregon Scientific - WMR968. Without checking real close I don't think what I have is quite up to the level of Davis. It works OK but the weather vane and wind speed cups will freeze up in a freezing rain. They do OK in the cold - its +5 deg right now - but freezing rain will lock them up. I've had the unit outside for 5 years now and this is the only negative thing I have to say about the unit.
You could spray them with silicone spray or Teflon spray and see if that deters the freezing up. Can't say it will work, but it's worth a try...
   / Weather Stations? Anyone have one on the farm? #14
The instructions with the weather station will say where to mount or not.
   / Weather Stations? Anyone have one on the farm? #15
The best would be to mount the wind sensor on the tower and the rain gauge close to the ground you can do this with the Davis VP2 as it has separate pieces
the all in 1 units are a compromise!! I have both..Here is some good info althought it's tough to be exact like they want it gives you some ideas...
http://www.comptus.com/PDF/CWOP_Guide.pdf
   / Weather Stations? Anyone have one on the farm? #16
The manual for the Davis units say:
General ISS Siting Guidelines
• Place the ISS away from sources of heat such as chimneys, heaters, air conditioners and exhaust vents.
• Place the ISS at least 100' (30 m) away from any asphalt or concrete roadway that readily absorbs and radiates heat in the sun. Avoid installations near fences or sides of buildings that receive a lot of sun during the day.
• Ideally, place the radiation shield of the ISS 5' (1.5 m) above the ground in the middle of gently sloping or flat, regularly mowed grassy or naturally landscaped area that drains well when it rains. For areas with average maximum yearly snow depths over 3' (0.9 m), mount the ISS 2' (0.6 m) above this depth.
Anemometer Siting Guidelines
• For best results, place the anemometer at least 7' (2.1 m) above surrounding obstructions such as trees or buildings that obstruct wind flow.
• If mounting on a roof, mount the anemometer at least 7' (2.1 m) above the roof apex (when using a Mounting Tripod, install the anemometer at the very top of the pole).
• If mounting the ISS and the anemometer together, such as on a pole or a wooden post, mount the anemometer so it is at least 12'' (0.3 m) above the top of the rain collector cone for best results.
• The standard for meteorological and aviation applications is to place the anemometer 33' (10 m) above the ground. Seek professional help for this type of installation.
• The standard for agricultural applications is to place the anemometer 6' (2 m) above the ground. This is important for evapotranspiration (ET) calculations.
   / Weather Stations? Anyone have one on the farm? #17
B7510hst and pwright, thanks for the info.
   / Weather Stations? Anyone have one on the farm? #18
   / Weather Stations? Anyone have one on the farm? #19
After working for the NWS for 18 years as an elect tech .....I now use ....a window. :p
   / Weather Stations? Anyone have one on the farm? #20
Davis Vantage Pro2 here. Love it. Two of them in the family. Very durable.
The "pro" stuff like you find on the highway towers is considerably more expensive than the "expensive" Davis.
The RM Young Anemometers are used on many of them here for wind speed. $950 for the base model, and that doesnt even include a display! R M Young Company 05103 WIND MONITOR
Then another $900 or so if you want a dedicated display. R M Young Company 06201 WIND TRACKER Display
You'll still need a barometer, thermometer, Humidity and Rain Gauge all costing about the same as the Anemometer (depending on brand)... Easy to spend a fortune on "pro" grade gear.
Many "pro" commercial sites run Davis VP2 gear. Its very good. id say 90% of the true "Pro" stuff albeit not as overbuilt.
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
*Selling at Royal Auction Zephyrhills, FL Location* (A59230)
*Selling at Royal...
AGT Hot Water Pressure Washer (A57453)
AGT Hot Water...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Pickup Truck (A59230)
