Wedding Pavilion that I'm building.
   / Wedding Pavilion that I'm building. #52
Eddie-
I just found your post and read through it. This project is really amazing. I think this is some of the best craftsmanship I have seen on any project on TBN. I really like the trusses with the curved support pieces. What color are they going to stain it? It would be a nice site for a weding as lon as they muck out the pasture before the wedding! Thanks for posting all the pictures. - Mike
Thanks Mike.
They gave me a list of what colors they want it stained with the main building to be a fairly basic brown. Not too dark or light. I get worried when it comes to color on anything. I've done some additions and remodels where the clients just ruined the rooms with the paint choices. The wife mentioned doing the panels in a differet shade then the posts, and doing allot of different stain color on different parts of it. I told her that is fine if that's what she wants, but to consider how busy it will look. It might look terrible if we did that and I really felt that one stain color will allow the features to stand out on their own without overpowering anybody. She agreed and we're back to a simple stainjob except for the medalion. That will get three colors. Dark, light and the same medium brown of the rest of the pavilion.
If the rain holds off, I should have the railing done today. With what I've done so far, it really changes the entire look of it.
Eddie
The weather has really slowed me down. Five days of temsp that never got above freezing, then rain befor that, and rain since then has only allowed me to put in 78 hours in the last three weeks. I've been able to do other things for some of my other clients to keep busy and to make a buck.
The original bid did not include the railing. I've found that clients like to get all fancy on the railing, then back off when they see what it costs. I've been working with them on various options and for awhile there, we had decided on iron panels with wood posts between them and either a finial on top of the post or a light of some kind. There was allot of deciding on the fly, and waiting until we got there to make the decicision.
When I told them that I was going to order the panels, the husband told me to hold on. He wanted to change the railing. He felt that the metal was too much and he wanted the railing to be wood. We waited until just a few weeks ago, and he decided that he wanted metal tubing from Lowes with wood on the bottom and top. I told him how much, and he said to go for it.
I modified his idea by replacing the wood posts for support, and using threaded rod through the middle of the tubing. I drilled through the deck and double nutted them on the bottom. I also cut the tubings for the railing to fit under the bottom for support.
The washers kind of stand out, but like the brackets, they will get painted brown and covered in stain to help them blend in. I can't make them disapear, but I can make them something that you wont' notice unless you are looking for them.
I used a forstner bit to drill out for the bolts on the top and then screwd it all together.
The short sections and the corner sections are very solid. The long, 15ft 6in back section has some give to it. I used 5/8's threaded rod there, as it's the biggest size that I coudl fit in the tubing. It's very tight, but with the distance being so long, it will move on you if you lean against it. It's there, but not very bad and I don't think most people wil even notice it.
I've already started on the arbor and should have it and the stairs done this week. We'er expecting another storm on Thursday, so that might be another delay. Then next week, I'm putting in a flagstone walkway. They found some oversized flagstones that are are too big to lay flat on a pallet. They are stacked on edge, and I'm still unsure how the heck I'm going to deal with getting them from being on edge, to being flat.
After the walkway is done, I'll clean all the wood, sand parts of it, and then stain it. I told them that I've never stained anything quite like this, and don't have a good idea of what it will cost them. If I do it, it's hourly. They said that it's my job, and will pay whatever it takes to do it right.
Gotta love it when you get great clients!!!!
Eddie
   / Wedding Pavilion that I'm building. #55
Very nicely done. I'll make sure I don't show these pictures to my wife... she'll want one. LOL
   / Wedding Pavilion that I'm building. #56
Eddie:
I dealt with that situation about a month ago with a pallet of flagstones that were 5' x 5' and 1 1/2" thick.
I used adjustable cargo straps to hold all but one of the flagstones upright, another strap around the bunch and the end one, and then cut the metal banding. They all stayed upright, and then we loosened the strap on the end one and carried it off. We worked our way through the stack, making sure the remainder stayed upright and took them one at a time.
One broke on us while it was vertical and pieces came crashing down. Be careful and be aware this can happen. Steel toed boots.
You need something very strong to support the stack while you take it apart. Maybe the FEL on a tractor.
We had two strong guys, and a geezer (me). You need two guys to disassemble the stack one one to stand back and make sure the operation is safe...
Hope this is clear. I can elaborate if you don't understand something.
   / Wedding Pavilion that I'm building. #57
The pavilion deserves better join on railing than that piece of sheetmetal joinery. Hmm, I guess it matches the rest, but it still sticks out.
   / Wedding Pavilion that I'm building. #58
Eddie, I tend to agree with Prokop about the corner treatment. Could you put some decorative flat black hinges (or flat black straps bent at 90 degrees) on the corners to tie the pieces together? That might look nicer than the metal angle plates.
Of course the railing is going to get a lot of abuse. People will be drawn to that railing to sit and push against. I think it may need a bit more support, but I could be wrong. You have to do what the client can afford and will agree to. It just seems to me that they cut corners on a very important part. If a group of people lean or sit on that rail and it collapses, they will wish they had allowed you to beef it up a bit more. I hope it doesn't happen, but my gut feeling says it will be problematic.
   / Wedding Pavilion that I'm building. #59
Another vote for a nicer railing corner.
I'm still looking for something nicer, but for now, it's form over function. WHen it's gets painted, I don't think you'll notice it, but we'll see.
For the bride to walk to the pavilion, she has to climb a set of stairs that I'm making, and then walk though an arbor, that I'm also making. I set the posts today, but started cutting, glueing and screwing the pieces for the top of the arbor together. Each one took 13 pieces of wood. After drying for two days, I sanded them down. My goal is to set them on the posts tomorrow.
Eddie
kids dirt bike (A53424)
kids dirt bike...
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
2008 Ford Focus SEL Sedan (A54815)
2008 Ford Focus...
2008 Peterbilt 340 Truck, VIN # 2NPRLN9X38M748650 (A54865)
2008 Peterbilt 340...
FORREST RIVER CHEROKEE CAMPER (A52472)
FORREST RIVER...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
