Weed control under fences
   / Weed control under fences #11
I have to spray around my poultry house. I have tried several different versions of Roundup and also several other products. By far the best that I have found is Pramitol. It is made to spray under new asphalt as far as I can tell. All that I know is that I only spray it once a year and that it works. Everything else that I have used, required me to spray 2-4 times a years.
   / Weed control under fences #12
As with others, I use Roundup, with a 40-50% concentrate base mixed with water to the strength recommended for "tough weed" control (twice "grass control" dilution). That said, it's not effective for a full 12 months, and it costs a fair bit (best price I've found is SAMS, usually in the Spring because that's the only time my local store carries the stuff). I'd prefer vegetation killer, but have trees too close the the fence line, and I'm afraid I'll zap the roots (in addition to which some of the vegetation killer products don't break down by natural processes, and can get into your water supply if you're dependent on a well).
   / Weed control under fences #13
"That said, it's not effective for a full 12 months"
It isn't supposed to be. Round-Up is a herbicide with zero residual effect. It kills what you put it on and you can plant new seed before the weeds are even completely dead. This is good in the field during spring planting, less good for this application. What the OP probably wants is a soil sterilizer. Your local agronomist can probably recommend one appropriate for your usage and labelled for your area.
   / Weed control under fences #14
I have to be careful here. CowBoyDoc probably has a pesticide/herbicide application license like I do, but for quick knockdown I use a blend of 2-4-D and Roundup Ultra. If you can obtain it in your area without a license, I'd suggest spraying it with a filter mask. We use it to control broadleaf weeds and thistle in our hayfields.
   / Weed control under fences #15
The patent has expired on Roundup's ingredient: glyphosate. You can get a glyphosate-containing weed killer a little cheaper than Roundup at farm supply stores.
Excess glyphosate gets tied up by clay particles in the soil. Just don't soak everything. Just coating most of the leaves will kill most green things. Some shrubs and really slick-bladed stuff may require a couple of applications.
Ralph
   / Weed control under fences #16
I use a herbacide.. and spray wand from a large hand held pump. Usually one application makes it the entire growing season. I usually mix in some permethrin oil emulsion product too.. That way I'm 'feeding' the termites while killing the weeds/grass.
Soundguy
   / Weed control under fences #17
Soundguy,
Yep gotta figure on killing termites in FL for sure /forums/images/graemlins/smile.gif Firewood stacks did not seem to make from one year to the next around Tampa.
A statistic I read somewhere said that pound for pound there were more termites in the world than people. Then there are the fire ants.......really fun to run over with a walk behind mower /forums/images/graemlins/frown.gif
   / Weed control under fences #18
Talk about fun... In our pasture.. near the manuer pile.. the is a nest of some sort of ground dwelling wasp.. ( yellowjacket? ).. big suckers.. mostly black.. but I do see a bit of yellow out of the corner of my eye as I shift into 4th gear on the tractor and try to get out of there as they angrilly shoot out of the hole I just ran over.... bad looking buggers. I've never been hit by one.. but I say one of my horses out there nosing around one day and then start bucking and kicking up a storm. When i put him up in his stall later.. he had a spot above his eye swelled up about half the size of a golfball....
Soundguy
   / Weed control under fences #19
Soundguy:
You need to park your rotary push mower, running wide open, over the hole. When the come out, they get "blended" by the blades.
   / Weed control under fences #20
</font><font color="blue" class="small">( Soundguy:
You need to park your rotary push mower, running wide open, over the hole. When the come out, they get "blended" by the blades. )</font>
Great idea, but my bumblebees, hornet, and yellowjackets always seem to be in an awkward place.
40' Sea Container (A50774)
40' Sea Container...
1998 SPARTAN MOTORHOME CHASSIS (A50324)
1998 SPARTAN...
E-Z Trail Head Cart (A50514)
E-Z Trail Head...
Toro Z Master 2000 Zero Turn Commercial Mower (A50322)
Toro Z Master 2000...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
