Weed Help!!
   / Weed Help!! #11
Weed-B-Gone and most of the other lawn weed killers are usually a mixture of 2-4-D and some other chemical like dicamba or picloram, etc. The 2-4-D takes care of about 80% of the weeds and the other chemical about 20%. If the weeds you are trying to kill are suseptable to 2-4-D on its own then go for it. It is a lot cheaper than the mixtures. Since your grass is new, I'd be a little careful about spraying weedkillers because it might be a little "tender". Try it on one spot before treating the whole yard.
I'm not too fond of the weed & feed type granular weed control chemicals because they don't seem to work too well for me but anything is better than hand picking weeds ... life is too short for that. A hose end sprayer works well or one of those dial-a-spray hose end sprayers. Then follow up with a pump-up sprayer to get the ones you missed. Your yard will be looking great in a couple of months. Best of luck.
   / Weed Help!! #12
I'd suggest a soil analaysis and then ammend the soil as required. In the patchy areas overseed and insure sufficient water is available.:D :D
Then start working on the weed problem.
Supposedly grass is at an optimum height at six inches tall. No verification for this.
   / Weed Help!! #13
Having grown up with a hoe in my hand....I realized there is a god when I discovered the joys of 2-4-D, and also Roundup.
:D Yep, it was wonderful to replace that hoe with something else, and also to replace the yo-yo or weed knife with a gasoline powered string trimmer.:D
   / Weed Help!! #14
Thanks Bird....you made me laugh.....good sense of humor!!!!:D
   / Weed Help!! #15
gamble77 said:
...that grass there is very "patchy". It is centiped (spelling) grass and the front yard is in the sun for most of the day.
...BUT I haven't cut my grass yet because I was told to let the centiped really take root and grow 4-5" or so before the first cut. Any advice would be appreciated bucause I am tired of seeing them in my yard!
Have you read up on centipede grass? It's one of my all time favorite lawn grasses for a few reasons. First and formost is that it grows VERY slowly. In my experience, you only mow it once or twice a year, and I've never seen it more then a few inches tall. I guess it could happen, but 4-5 inches seems a bit much for it.
Once it's established, it creates a solid surface that does an awesome job of choking out all other plants around it. The problem is that it grows so slowly, that it might take 2 to 3 years to cover an area.
When I've had it planted, I also plant bermuda grass with it. The bermuda grows quickly and locks the soil together giving you a lawn while the centipede gets established. Then as the centipede spreads out, it chokes off the bermuda and takes over. In time, the centipede will be the only thing left.
In lawns where this is done, you can see the two grasses competing with each other, but where the centepide is taking over, it's flat and very short. It's also a deeper color of green, which is another reason I like it so much.
For weeds, I've had good luck with Scotts Plus fertalizer for warm season grasses. I just broadcast spread it over a wet lawn and let the granules stick to the weeds. In a week or two, most everything but the grass is dead.
Eddie
   / Weed Help!! #16
If you are using 24D it really doesn't take much at all. I usually only mix 1.5 quarts in my 100 gallon sprayer to do about 5 acres. I believe the bottles of it that I get are 46% active ingredient at the feed store. It kills most of the weeds in that field. We have some "lake weed" the locals call it that takes nearly 4 quarts but luckily that is mostly gone now. Some sticker agent in the sprayer really helps it a lot too. The brand name of that I use here is crop oil I think. It's just an oily liquid that goes in the spray tank with it and helps it coat the broadleaves better. Also remember that 24D works best when it is hot and dry outside. Over 80 degrees average it works it's best. It's a waste of money spraying it under 60 degrees I learned. And don't spray it at all if you have any cotton, soybean or any other similar crops growing within sight. Unless you want to be buying that years crop. It takes very little of it drifting on the wind to wipe out a cotton field. My neighbor with his crop dusters and roundup has killed out my crops twice now without even an apology.I try to make sure the wind is blowing away from him though. He's lucky I'm not as stupid as he is.
I don't think I'd recommend using 24D in a handheld sprayer. Read the label and you'll understand. I put the charcoal filters in my cab ac intake everytime I go spraying just about anything now days. Those labels scare me and I've been exposed to enough through 15 years of the Military. I certainly don't need to add to it any.
If you are using MSMA I strongly recommend keeping your animals off the grass for a LONG time. That stuff is super toxic to animals. It was recommended to me to spray MSMA on one of my horse pastures a few years ago to get rid of some johnson grass, then right after I did it I read the bottle. It said to remove all animals from the pasture for at least 6 months after spraying. I was not very happy at all with that knuckle head at the feed store that told me he did it all the time on his horse pasture.
   / Weed Help!! #17
Yo-yo? You mean that "D" shaped thing on the end of a handle that has two sharp edges that can cut you if you aren't careful while moving it from one storage location to another storage location? I haven't used mine in years, but I keep it around for some unknown reason.:rolleyes:
I found at my last house that if I just waited a couple of weeks, the Saint Augustine grass would choke out weeds. I watched my neighbor treat his weeds and they would disappear at the same time as mine. He was sure the herbicide was working and I am sure it was just Mother Nature.:) Year after year, the spring weeds popped up and were choked out by the grass when it got going. I just mowed the weeds to prevent them from going to seed. That was my yard with very thick grass. Others may not have the same conditions. YMMV
   / Weed Help!! #18
Yep, Jim, that's that tool I was talking about. The last time I saw one used was in Cool Hand Luke.:D But I got more experience with one than I wanted in my early teens.
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2016 FREIGHTLINER CASCADIA TANDEM AXL MID ROOF SLEEPER TRUCK (A59575)
2016 FREIGHTLINER...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
2001 PETERBILT 379 (A58214)
2001 PETERBILT 379...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
