Weight Distribution Hitch Question
   / Weight Distribution Hitch Question #81
I have read some of the manuals that come with these aftermarket hitches and they all say that you should follow the vehicle manufactures recommended weights as published in the manual. That is an easy out for these hitch manufacturers.
It's not an easy out at all... The ratings from the manufacturer take into consideration ALL of the components involved in towing. Putting an aftermarket hitch on your vehicle may provide a beefier hitch component, but it does not change the weight ratings for the axles, the strength of the frame, or any of the other pieces that make up the full "system". The hitch manufacturer is not qualified to provide a new tow rating for your vehicle as the result of bolting on a new hitch.
   / Weight Distribution Hitch Question #82
aczlan said:
A WD hitch is going to put at least as much strain on the frame as a non-WD hitch. Think about the loading, instead of vertical downward loading in the back of the hitch, you now have upward loading on the back of the hitch and at least as much downward loading on the the front of the hitch. See below for an illustration
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=277615"/>
What WD gives you is less bending movement on the hitch which allows a lighter (and cheaper) crosstube.
Agree 100%.
Aaron Z
Most hitches are attached using about 6 bolts. It is obviously best to spread the load to the frame using all bolts vs just the rear bolts. I would also venture to say that the further rearward points on the frame (last 6") is considerably weaker than say 18" from the end. I agree that there is less torque being applied to the cross tube which in turn translates to what I just mentioned.
   / Weight Distribution Hitch Question #83
While I have installed heavier hitches I have never done so with the intent of exceeding the trucks ratings. I am doing so to take full advantage of the truck since the factory hitch was not up to par so to speak.
Now this is not fully a true statement. I have towed above and beyond my trucks capability a few times and I know the risk. But I would have done so with the weaker factory hitch also and in that case been taking a much greater risk. Again, the reason for the better stronger hitch is to take advantage of the trucks capability.
Chris
   / Weight Distribution Hitch Question #84
Not really since it is actually reversing the conventional torque load on the tube to the other direction to load the front tires. Can't really make it lighter.
I meant less rotational movement, not bending. Yes, there is more vertical downforce on the hitch, but there is less rotational force as well.
Aaron Z
   / Weight Distribution Hitch Question #85
Not that I want to over dramatize the issue but I am seeing a lot of people towing dangerous setups and not even knowing it. If Jim-Bob kills a family member I will be even more active.
I second that! I am regularly horrified by what I see rolling down the road behind people's trucks.
   / Weight Distribution Hitch Question #86
meburdick said:
Every manufacturer advertises their vehicle's "max towing capacity" as what it is... the "max" capacity. That 2500 has a max towing capacity of 10,000 lbs. The "fine print" will tell you that you will need to achieve this limit by way of using a WDH, and if you do not, you will not be able to tow a trailer with a GTWR of over 5,000 lbs. That number is NOT the max towing capacity.
If the max tongue weight were 700 lbs, the max trailer weight without a WDH would be 7,000 lbs. It is EXACTLY a factor of 10 between the two because of the max tongue weight and the fact that it must represent no less than 10% of the GTWR.
I understand that a limit was exceeded, I understand that "weakest link in the chain" notion. I've said this before, and I will say it again... I'm not trying to tell anyone that the numbers advertised by the manufacturer are wrong... I am merely trying to help people understand WHY the numbers without a WDH come out as they do. I am in complete agreement with Wolfpack2 and the statement about adhering to guidelines.
The comment about a WDH being there to "change the center of gravity" isn't really correct. It's referred to as a "weight distributing" hitch for a reason... It's purpose is to distribute some of the tongue weight of the trailer to axles other than the rear axle of the tow vehicle. As a result, the center of gravity will change, but that isn't its sole purpose.
I can't speak for DiamondPilot, but I have a '11 Tundra with the integrated hitch. Maybe the comments you're thinking of are mine.
I agree with what you are saying. Max tow capacity ratings are if every other piece of the puzzle or link to the chain is met. Any item not met is the limiting factor and sets the "current max tow capacity". This guy on the job site had a towing capacity of 5000 lbs /500lbs tongue with his setup. He was hauling approximately 9000 lbs and all he needed was a $200 WD hitch and all would have been legal.
I was definitely referring to diamondpilot but he tows with a Ford and a Nissan.
I have a toyhauler trailer that has about 20% tongue weight. It has about 1000 lbs on the tongue and 4000 on the axles when loaded. Unloaded it is about 10% so I obviously use a WD with this trailer. The 10% number is a minimum number which can get someone in trouble well before on the tongue vs the trailer weight.
   / Weight Distribution Hitch Question #87
I meant it was an easy out for the aftermarket manufacturer to not be liable if the hitch was stronger than the truck frame or an unsafe condition was created by using their higher capacity hitch. It was in regards to joshuabardswell's comment.
You and I are on the same page and are in agreement. I am just wanting to make sure that when aftermarket hitches are utilized, they consider, as diamondpilot does, and use the truck capacities and not the new hitch capacities.
   / Weight Distribution Hitch Question #88
Taking it a little further, it's best to always find and use the lowest rating of any individual "piece" since that will always be the limiting factor. You can't take a 1992 Toyota Pickup with a 4 cylinder motor, put a Class V hitch on it, and expect to pull a 15,000 lb trailer. The whole system has to work together and the least capable part of the system has to be where the limitations come from.
   / Weight Distribution Hitch Question #89
Can you use a wd hitch on a penal hitch?
   / Weight Distribution Hitch Question #90
2007 Vantage P-42-1000 42ft. T/A Dry Bulk Pneumatic Tank Trailer (A55973)
2007 Vantage...
PALLET TOTE OF JARS & MISC (A58374)
PALLET TOTE OF...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
IRGC80 Lifted Electric Golf Cart **Unassembled**(New/Unused) Plugs into standard 110 outlet , Com... (A59225)
IRGC80 Lifted...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56435)
2022 John Deere...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
